[postgis-tickets] [PostGIS] #3980: [SFCGAL] Potential access to freed memory
trac at osgeo.org
Tue Jan 30 12:40:10 PST 2018
Reporter: lucasvr | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.4
Component: sfcgal | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
The POSTGIS2SFCGALGeometry might be making a deep copy,
in which case you don't need to postpone the PG_FREE_IF_COPY
if its inputs, can you check ?
The final lines instead (postponing freeing inputs to
lwgeom_from_gserialized) are really needed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3980#comment:6>
