[postgis-tickets] r16258 - Do not try to test upgrade from-to the same version
Sandro Santilli
strk at kbt.io
Thu Jan 11 08:43:54 PST 2018
Author: strk
Date: 2018-01-11 08:43:53 -0800 (Thu, 11 Jan 2018)
New Revision: 16258
trunk/utils/check_all_upgrades.sh
Modified: trunk/utils/check_all_upgrades.sh
--- trunk/utils/check_all_upgrades.sh 2018-01-11 16:35:51 UTC (rev 16257)
+++ trunk/utils/check_all_upgrades.sh 2018-01-11 16:43:53 UTC (rev 16258)
@@ -14,6 +14,10 @@
files=`'ls' postgis--* | grep -v -- '--.*--' | sed 's/^postgis--\(.*\)\.sql/\1/'`
for fname in unpackaged $files; do
from_version="$fname"
+ if test "${from_version}" = "${to_version}"; then
+ # TODO: upgrade to ${from_version}next instead ?
+ continue
+ fi
UPGRADE_PATH="${from_version}--${to_version}"
if test -e postgis--${UPGRADE_PATH}.sql; then
echo "Testing upgrade $UPGRADE_PATH"
