[postgis-tickets] r16259 - Add lost mention of Shoaib Burq.
Darafei
komzpa at gmail.com
Thu Jan 11 09:41:42 PST 2018
Author: komzpa
Date: 2018-01-11 09:41:42 -0800 (Thu, 11 Jan 2018)
New Revision: 16259
trunk/liblwgeom/cunit/cu_out_encoded_polyline.c
trunk/liblwgeom/lwout_encoded_polyline.c
Reformat Encoded Polyline out function to fit 80 columns per strk's request.
Modified: trunk/liblwgeom/cunit/cu_out_encoded_polyline.c
--- trunk/liblwgeom/cunit/cu_out_encoded_polyline.c 2018-01-11 16:43:53 UTC (rev 16258)
+++ trunk/liblwgeom/cunit/cu_out_encoded_polyline.c 2018-01-11 17:41:42 UTC (rev 16259)
@@ -28,7 +28,8 @@
g = lwgeom_from_wkt(in, LW_PARSER_CHECK_NONE);
h = lwgeom_to_encoded_polyline(g, precision);
- if (strcmp(h, out)) fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, h, out);
+ if (strcmp(h, out))
+ fprintf(stderr, "\nIn: %s\nOut: %s\nTheo: %s\n", in, h, out);
CU_ASSERT_STRING_EQUAL(h, out);
@@ -40,17 +41,22 @@
out_encoded_polyline_test_geoms(void)
/* Magic Linestring */
- do_encoded_polyline_test("SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,33.6673 38.6972,33.6626 38.6871)",
- 5,
- "k~fkFsvolEbe at bVvVzJb~@j\\");
+ do_encoded_polyline_test(
+ "SRID=4326;LINESTRING(33.6729 38.7071,33.6692 38.701,"
+ "33.6673 38.6972,33.6626 38.6871)",
+ 5,
+ "k~fkFsvolEbe at bVvVzJb~@j\\");
return;
/* Linestring */
- "LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)", 5, "_p~iF~ps|U_ulLnnqC_mqNvxq`@");
+ "LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)",
+ 5,
+ "_p~iF~ps|U_ulLnnqC_mqNvxq`@");
/* MultiPoint */
- do_encoded_polyline_test("MULTIPOINT(-120.2 38.5,-120.95 40.7)", 5, "_p~iF~ps|U_ulLnnqC");
+ "MULTIPOINT(-120.2 38.5,-120.95 40.7)", 5, "_p~iF~ps|U_ulLnnqC");
static void
@@ -58,10 +64,12 @@
/* SRID - with PointArray */
- do_encoded_polyline_test("SRID=4326;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
+ "SRID=4326;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
/* wrong SRID */
- do_encoded_polyline_test("SRID=4327;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
+ "SRID=4327;LINESTRING(0 1,2 3)", 5, "_ibE?_seK_seK");
static void
@@ -69,13 +77,16 @@
/* Linestring */
- do_encoded_polyline_test("LINESTRING(-0.250691 49.283048,-0.250633 49.283376,-0.250502 49.283972,-0.251245 "
- "49.284028,-0.251938 49.284232,-0.251938 49.2842)",
- 6,
- "o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
+ "LINESTRING(-0.250691 49.283048, -0.250633 49.283376,"
+ "-0.250502 49.283972, -0.251245 49.284028, -0.251938 "
+ "49.284232, -0.251938 49.2842)",
+ 6,
+ "o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?");
/* MultiPoint */
- do_encoded_polyline_test("MULTIPOINT(-120.2 38.5,-120.95 40.7)", 3, "gejAnwiFohCzm@");
+ "MULTIPOINT(-120.2 38.5,-120.95 40.7)", 3, "gejAnwiFohCzm@");
Modified: trunk/liblwgeom/lwout_encoded_polyline.c
--- trunk/liblwgeom/lwout_encoded_polyline.c 2018-01-11 16:43:53 UTC (rev 16258)
+++ trunk/liblwgeom/lwout_encoded_polyline.c 2018-01-11 17:41:42 UTC (rev 16259)
@@ -19,6 +19,7 @@
* Copyright 2014 Kashif Rasul <kashif.rasul at gmail.com> and
+ * Shoaib Burq <saburq at gmail.com>
@@ -41,7 +42,8 @@
case MULTIPOINTTYPE:
return lwmmpoint_to_encoded_polyline((LWMPOINT*)geom, precision);
default:
- lwerror("lwgeom_to_encoded_polyline: '%s' geometry type not supported", lwtype_name(type));
+ lwerror("lwgeom_to_encoded_polyline: '%s' geometry type not supported",
+ lwtype_name(type));
return NULL;
@@ -72,7 +74,8 @@
stringbuffer_t* sb;
double scale = pow(10, precision);
- /* Take the double value and multiply it by 1x10^precision, rounding the result */
+ /* Take the double value and multiply it by 1x10^precision, rounding the
+ * result */
prevPoint = getPoint2d_cp(pa, 0);
delta[0] = round(prevPoint->y * scale);
delta[1] = round(prevPoint->x * scale);
@@ -82,11 +85,13 @@
const POINT2D* point = getPoint2d_cp(pa, i);
delta[2 * i] = round(point->y * scale) - round(prevPoint->y * scale);
- delta[(2 * i) + 1] = round(point->x * scale) - round(prevPoint->x * scale);
+ delta[(2 * i) + 1] =
+ round(point->x * scale) - round(prevPoint->x * scale);
prevPoint = point;
- /* value to binary: a negative value must be calculated using its two's complement */
+ /* value to binary: a negative value must be calculated using its two's
+ * complement */
for (i = 0; i < pa->npoints * 2; i++)
/* Multiply by 2 for a signed left shift */
