[postgis-tickets] [PostGIS] #3984: intersections between valid geometry and raster throw TopologyException
PostGIS trac at osgeo.org
Thu Jan 11 16:38:07 PST 2018
 Reporter:  turntwo463      |      Owner:  Bborie Park
     Type:  defect          |     Status:  new
 Priority:  critical        |  Milestone:  PostGIS 2.3.6
Component:  raster          |    Version:  2.3.x
 Keywords:  intersections,  |
 A significant proportion of intersections between polygons and raster
 often fail with ERROR: GEOSIntersects: TopologyException: side location
 conflict. The polygons are valid when checked with ST_IsValid.
 An example query that can reproduce this is the following:
 SELECT rid, rast, filename, ST_Intersection(rast,
          ST_GeomFromText('MULTIPOLYGON (((586930.2651485216
 4532526.288145695, 586929.162455693 4532515.09231752, 586919.2106084262
 4532516.072488924,
                          586920.6808655312 4532531.000259823,
 586926.9007700728 4532530.387652696, 586930.2651485216
 4532526.288145695)))', 26918))
         FROM processing.dem where ST_Intersects(rast,
 4532516.072488924,
 The dem table was loaded using the following:
 raster2pgsql -c -I -s 26918
 "C:\temp\USGS_NED_one_meter_x58y454_NJ_SdL5_2014_IMG_2015.img" -F -t 25x25
 processing.dem | psql -d mydb -h 127.0.0.1 -p 5432 -U the_admin
 The dem table can be downloaded from:
 https://prd-
 tnm.s3.amazonaws.com/StagedProducts/Elevation/1m/IMG/USGS_NED_one_meter_x58y454_NJ_SdL5_2014_IMG_2015.zip
 Version information for PostGIS is:
 POSTGIS="2.3.2 r15302" GEOS="3.6.1-CAPI-1.10.1 r4317" PROJ="Rel. 4.9.1, 04
 March 2015" GDAL="GDAL 2.1.3, released 2017/20/01" LIBXML="2.7.8"
 LIBJSON="0.12" TOPOLOGY RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3984>
