[postgis-tickets] [PostGIS] #3735: Enable Gitea pull requests for Jenkins using web hoos
trac at osgeo.org
Fri Jan 19 11:56:57 PST 2018
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Management 2.0
Component: buildbots | Version: 2.3.x
Resolution: | Keywords:
Comment (by strk):
According to a Gitea developer, since 1.2.0 (we're running 1.3.x) Gitea
supports an API to signal status of each commit in each branch of each
repository. And chances are that the Jenkins plugin does support such API,
so we could be able to setup a proper watcher reporting with automatic
badges on each commit. The relative PR includes a screenshot:
https://github.com/go-gitea/gitea/pull/1688
Newer Drone should also be supporting it, since this PR was merged (not
sure which version):
https://github.com/drone/drone/pull/2017
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3735#comment:9>
