[postgis-tickets] [PostGIS] #3999: configure should error out if building from git/svn if xsltproc is not installed
trac at osgeo.org
Fri Jan 19 14:59:19 PST 2018
installed
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.4
Component: build/upgrade/install | Version: 2.4.x
Keywords: |
When we package, we include the comments.sql scripts in the tar ball.
When building from git or svn, these scripts are generated using xsltproc.
The comments scripts are needed for postgis extension scripts.
As such in order to build the extensions from git/svn repo, xsltproc must
be installed on the build machine and configure should error out if it is
not.
This test is only necessary if building from git/svn.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3999>
