[postgis-tickets] [PostGIS] #3813: Dronie and gitlab running GEOS 3.4.2 need to be upgraded to 3.5.0
trac at osgeo.org
Mon Jan 22 04:35:12 PST 2018
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Comment (by strk):
In [changeset:"16353" 16353]:
#!CommitTicketReference repository="" revision="16353"
[drone] Use trisquel2 image, test all pgsql versions and upgrades
The new docker image also uses newer GEOS (3.6.2).
References #3813 for 2.4 branch
NOTE: could not use -Werror in this branch as it would fail
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3813#comment:13>
