[postgis-tickets] [PostGIS] #3813: Dronie and gitlab running GEOS 3.4.2 need to be upgraded to 3.5.0
trac at osgeo.org
Mon Jan 22 04:37:28 PST 2018
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.0
Component: buildbots | Version: trunk
Resolution: | Keywords:
Comment (by strk):
In [changeset:"16354" 16354]:
#!CommitTicketReference repository="" revision="16354"
[drone] Use trisquel2 image, test all pgsql versions and upgrades
The new docker image also uses newer GEOS (3.6.2).
References #3813 for 2.3 branch
NOTE: -Werror is not used in this branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3813#comment:14>
