[postgis-tickets] [PostGIS] #3813: Dronie and gitlab running GEOS 3.4.2 need to be upgraded to 3.5.0
PostGIS trac at osgeo.org
Mon Jan 22 04:39:58 PST 2018
  Reporter:  robe       |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS 2.5.0
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"16355" 16355]:
 #!CommitTicketReference repository="" revision="16355"
 [drone] Use trisquel2 image, test all pgsql versions and upgrades
 The new docker image also uses newer GEOS (3.6.2).
 Closes #3813 in 2.2 branch
 NOTE: -Werror is not used in this branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3813#comment:15>
