[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
trac at osgeo.org
Tue Mar 13 05:55:10 PDT 2018
Reporter: tiiipponen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by tiiipponen):
Hi. Nice to hear that this is taking steps forward.
I agree the tolerance concept with minimum of two (or five and maximum of
? (10 000?)) segments can be good fix here.
I looked from one of our data, what is the smallest tolerance to keep arcs
with two segments and here are the results in ascending order:
order_id tolerance
1 0.0 (under accuracy of presentation maybe)
2 1.8189894035458565e-12
158 1.3274114678551996e-6
516 0.00011366017865555023
698 0.00100533397314706
848 0.010147203454144105
1157 0.1016548941997506
That is real life example and "minimum of 2 segments" parameter is needed.
The question then rises: what is the default tolerance for linearization?
In Oracle we have used tolerance 0.0005 in metadata
"user_sdo_geom_metadata".
I have not seen place to put tolerance for table-data in PostGIS. At least
it is not in view "public.geometry_columns".
I can imagine that not everybody are satisfied with highest possible
tolerance, because of its impact to efficiency.
On the other hand too big tolerance gives more erroneus results from
functions like ST_Intersects() etc.
It would be good if users could select tolerance as they want in table
level or somehow.
I am willing to hear your thoughts about this.
I am also willing to hear your thoughts about PostGIS's future development
for arc-geometry handling. Are there plans to do topology- queries etc.
without need to linearizing arcs? I can see some similar base development
done to PostGIS code already.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:11>
