[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
trac at osgeo.org
Tue Mar 13 08:57:33 PDT 2018
Reporter: tiiipponen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by strk):
> The question then rises: what is the default tolerance for
> linearization?
Default is 32 segments per quadrant (which means single segment
if the arc is 2.81250 degrees or less)
The above default is documented in
http://postgis.net/docs/manual-2.4/ST_CurveToLine.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:12>
