[postgis-tickets] [PostGIS] #4052: search_path related bug in sql wrapper function?
PostGIS trac at osgeo.org
Thu Mar 22 06:30:29 PDT 2018
 Reporter:  Lonepsycho  |      Owner:  pramsey
     Type:  defect      |     Status:  new
 Priority:  high        |  Milestone:  PostGIS 2.4.4
Component:  postgis     |    Version:  2.4.x
 Keywords:              |
 version()
 PostgreSQL 9.6.8 on x86_64-pc-linux-gnu (Debian 9.6.8-1.pgdg80+1),
 compiled by gcc (Debian 4.9.2-10+deb8u1) 4.9.2, 64-bit
 postgis_full_version()
 POSTGIS="2.3.3 r15473" GEOS="3.4.2-CAPI-1.8.2 r3921" SFCGAL="1.3.0"
 PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26"
 LIBXML="2.9.1" LIBJSON="0.11.99" RASTER
 After migrating to PostgreSQL 9.6.8 the fun begun. There is a problem with
 wrapper functions (i believe c functions have been fixed) related to
 postgres security patch that targets default public schema usage;
 in our case we have some functional indexes, that fail to pass test
 SET SEARCH_PATH TO pg_catalog;
 ANALYZE table;
 the function in question is
 CREATE OR REPLACE FUNCTION public.st_buffer (
   public.geography,
   double precision,
   text
 RETURNS public.geography AS
 $body$
 SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1),
 public._ST_BestSRID($1)), $2, $3), 4326))
 $body$
 LANGUAGE 'sql'
 IMMUTABLE
 RETURNS NULL ON NULL INPUT
 SECURITY INVOKER
 COST 100;
 COMMENT ON FUNCTION public.st_buffer(public.geography, double precision,
 text)
 IS 'args: g1, radius_of_buffer, buffer_style_parameters - (T)Returns a
 geometry covering all points within a given distancefrom the input
 geometry.';
 pg_restore fails:
 ERROR:  function geometry(public.geography) does not exist at character 54
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 QUERY:  SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1),
 public._ST_BestSRID($1)), $2), 4326))
 CONTEXT:  SQL function "st_buffer" during inlining
 CREATE INDEX idx_tg_geocode_cache_box ON gpt_geodata.tg_geocode_cache
 USING gist (((public.st_buffer((public.st_setsrid(public.st_makepoint(lon,
 lat), 4326))::public.geography, (3)::double
 precision))::public.geometry));
 ANALYZE TABLE ... also fails. Guess same problem persists in all SQL,
 wrapper, postgis functions that target other postgis functions.
 Marius
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4052>
