[postgis-tickets] r16482 - schema qualify geography functions (including ST_Buffer)
Regina Obe
lr at pcorp.us
Thu Mar 22 05:09:53 PDT 2018
Author: robe
Date: 2018-03-22 17:09:53 -0700 (Thu, 22 Mar 2018)
New Revision: 16482
branches/2.4/NEWS
branches/2.4/postgis/geography.sql.in
References #4052 for PostGIS 2.4.4
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-03-22 15:45:31 UTC (rev 16481)
+++ branches/2.4/NEWS 2018-03-23 00:09:53 UTC (rev 16482)
@@ -11,7 +11,8 @@
(Björn Esser)
- #4025, Incorrect answers for temporally "amost overlapping" ranges
- #4017, lwgeom lexer memory corruption (Peter E)
+ - #4052, schema qualify several functions in geography
* Enhancements *
- #3992, Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect pkg-config
(Bas Couwenberg)
Modified: branches/2.4/postgis/geography.sql.in
--- branches/2.4/postgis/geography.sql.in 2018-03-22 15:45:31 UTC (rev 16481)
+++ branches/2.4/postgis/geography.sql.in 2018-03-23 00:09:53 UTC (rev 16482)
@@ -23,7 +23,7 @@
RETURNS cstring
AS 'MODULE_PATHNAME','postgis_typmod_out'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
-- Availability: 1.5.0
CREATE OR REPLACE FUNCTION geography_in(cstring, oid, integer)
RETURNS geography
@@ -75,7 +75,7 @@
CREATE OR REPLACE FUNCTION geography(geography, integer, boolean)
RETURNS geography
AS 'MODULE_PATHNAME','geography_enforce_typmod'
- LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
CREATE CAST (geography AS geography) WITH FUNCTION geography(geography, integer, boolean) AS IMPLICIT;
@@ -103,11 +103,11 @@
RETURNS TEXT
AS 'MODULE_PATHNAME','LWGEOM_asText'
-- Availability: 1.5.0 - this is just a hack to prevent unknown from causing ambiguous name because of geography
CREATE OR REPLACE FUNCTION ST_AsText(text)
RETURNS text AS
- $$ SELECT ST_AsText($1::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_AsText($1::@extschema at .geometry); $$
LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
@@ -150,17 +150,17 @@
-- Changed: 2.4.0 Limit to only list things that are tables
CREATE OR REPLACE VIEW geography_columns AS
SELECT
- current_database() AS f_table_catalog,
- n.nspname AS f_table_schema,
- c.relname AS f_table_name,
+ current_database() AS f_table_catalog,
+ n.nspname AS f_table_schema,
+ c.relname AS f_table_name,
a.attname AS f_geography_column,
postgis_typmod_dims(a.atttypmod) AS coord_dimension,
postgis_typmod_srid(a.atttypmod) AS srid,
postgis_typmod_type(a.atttypmod) AS type
- FROM
- pg_class c,
- pg_attribute a,
- pg_type t,
+ FROM
+ pg_class c,
+ pg_attribute a,
+ pg_type t,
pg_namespace n
WHERE t.typname = 'geography'
AND a.attisdropped = false
@@ -194,50 +194,50 @@
-CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,int4)
- RETURNS bool
+CREATE OR REPLACE FUNCTION geography_gist_consistent(internal,geography,int4)
+ RETURNS bool
AS 'MODULE_PATHNAME' ,'gserialized_gist_consistent'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_compress(internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_compress(internal)
+ RETURNS internal
AS 'MODULE_PATHNAME','gserialized_gist_compress'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_penalty(internal,internal,internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_penalty(internal,internal,internal)
+ RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_penalty'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_picksplit(internal, internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_picksplit(internal, internal)
+ RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_picksplit'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_union(bytea, internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_union(bytea, internal)
+ RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_union'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_same(box2d, box2d, internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_same(box2d, box2d, internal)
+ RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_same'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_gist_decompress(internal)
- RETURNS internal
+CREATE OR REPLACE FUNCTION geography_gist_decompress(internal)
+ RETURNS internal
AS 'MODULE_PATHNAME' ,'gserialized_gist_decompress'
LANGUAGE 'c';
-CREATE OR REPLACE FUNCTION geography_overlaps(geography, geography)
- RETURNS boolean
+CREATE OR REPLACE FUNCTION geography_overlaps(geography, geography)
+ RETURNS boolean
AS 'MODULE_PATHNAME' ,'gserialized_overlaps'
@@ -246,7 +246,7 @@
LEFTARG = geography, RIGHTARG = geography, PROCEDURE = geography_overlaps,
COMMUTATOR = '&&',
RESTRICT = gserialized_gist_sel_nd,
- JOIN = gserialized_gist_joinsel_nd
+ JOIN = gserialized_gist_joinsel_nd
-- Availability: 2.2.0
@@ -263,8 +263,8 @@
-CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, int4)
- RETURNS float8
+CREATE OR REPLACE FUNCTION geography_gist_distance(internal, geography, int4)
+ RETURNS float8
AS 'MODULE_PATHNAME' ,'gserialized_gist_geog_distance'
LANGUAGE 'c';
@@ -315,19 +315,19 @@
AS 'MODULE_PATHNAME', 'geography_gt'
--- Availability: 1.5.0
+-- Availability: 1.5.0
CREATE OR REPLACE FUNCTION geography_ge(geography, geography)
RETURNS bool
AS 'MODULE_PATHNAME', 'geography_ge'
CREATE OR REPLACE FUNCTION geography_eq(geography, geography)
RETURNS bool
AS 'MODULE_PATHNAME', 'geography_eq'
CREATE OR REPLACE FUNCTION geography_cmp(geography, geography)
RETURNS integer
AS 'MODULE_PATHNAME', 'geography_cmp'
@@ -398,11 +398,11 @@
RETURNS text
AS 'MODULE_PATHNAME','geography_as_svg'
CREATE OR REPLACE FUNCTION ST_AsSVG(text)
RETURNS text AS
- $$ SELECT ST_AsSVG($1::@extschema at .geometry,0,15); $$
+ $$ SELECT @extschema at .ST_AsSVG($1::@extschema at .geometry,0,15); $$
@@ -534,11 +534,11 @@
RETURNS float8
AS 'SELECT @extschema at ._ST_Distance($1, $2, 0.0, true)'
CREATE OR REPLACE FUNCTION ST_Distance(text, text)
RETURNS float8 AS
- $$ SELECT ST_Distance($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_Distance($1::@extschema at .geometry, $2::@extschema at .geometry); $$
-- Only expands the bounding box, the actual geometry will remain unchanged, use with care.
@@ -565,7 +565,7 @@
CREATE OR REPLACE FUNCTION ST_DWithin(text, text, float8)
RETURNS boolean AS
- $$ SELECT ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3); $$
+ $$ SELECT @extschema at .ST_DWithin($1::@extschema at .geometry, $2::@extschema at .geometry, $3); $$
LANGUAGE 'sql' IMMUTABLE _PARALLEL;
@@ -580,7 +580,7 @@
AS 'MODULE_PATHNAME','geography_distance_uncached'
COST 100;
-- Calculate the distance in geographics *without* using the caching code line or tree code
CREATE OR REPLACE FUNCTION _ST_DistanceUnCached(geography, geography, boolean)
RETURNS float8
@@ -593,7 +593,7 @@
AS 'SELECT @extschema at ._ST_DistanceUnCached($1, $2, 0.0, true)'
LANGUAGE 'sql' IMMUTABLE STRICT;
--- Calculate the distance in geographics using the circular tree code, but
+-- Calculate the distance in geographics using the circular tree code, but
-- *without* using the caching code line
CREATE OR REPLACE FUNCTION _ST_DistanceTree(geography, geography, float8, boolean)
RETURNS float8
@@ -601,7 +601,7 @@
COST 100;
CREATE OR REPLACE FUNCTION _ST_DistanceTree(geography, geography)
RETURNS float8
@@ -620,7 +620,7 @@
RETURNS boolean
AS 'SELECT $1 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($2,$3) AND $2 OPERATOR(@extschema at .&&) @extschema at ._ST_Expand($1,$3) AND @extschema at ._ST_DWithinUnCached($1, $2, $3, true)'
LANGUAGE 'sql' IMMUTABLE;
@@ -633,7 +633,7 @@
CREATE OR REPLACE FUNCTION ST_Area(text)
RETURNS float8 AS
- $$ SELECT ST_Area($1::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_Area($1::@extschema at .geometry); $$
@@ -694,7 +694,7 @@
CREATE OR REPLACE FUNCTION ST_Covers(text, text)
RETURNS boolean AS
- $$ SELECT ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_Covers($1::@extschema at .geometry, $2::@extschema at .geometry); $$
-- Only implemented for polygon-over-point
@@ -707,7 +707,7 @@
CREATE OR REPLACE FUNCTION ST_CoveredBy(text, text)
RETURNS boolean AS
- $$ SELECT ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_CoveredBy($1::@extschema at .geometry, $2::@extschema at .geometry); $$
-- Availability: 2.1.0
@@ -726,7 +726,7 @@
CREATE OR REPLACE FUNCTION ST_Intersects(text, text)
RETURNS boolean AS
- $$ SELECT ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry); $$
+ $$ SELECT @extschema at .ST_Intersects($1::@extschema at .geometry, $2::@extschema at .geometry); $$
@@ -744,43 +744,43 @@
CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8)
RETURNS geography
- AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
+ AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2), 4326))'
-- Availability: 2.3.x
CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, integer)
RETURNS geography
- AS 'SELECT geography(ST_Transform(ST_Buffer(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
+ AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Buffer(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1)), $2, $3), 4326))'
CREATE OR REPLACE FUNCTION ST_Buffer(geography, float8, text)
RETURNS geography
CREATE OR REPLACE FUNCTION ST_Buffer(text, float8)
RETURNS geometry AS
- $$ SELECT ST_Buffer($1::@extschema at .geometry, $2); $$
+ $$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2); $$
CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, integer)
RETURNS geometry AS
- $$ SELECT ST_Buffer($1::@extschema at .geometry, $2, $3); $$
+ $$ SELECT @extschema at .ST_Buffer($1::@extschema at .geometry, $2, $3); $$
CREATE OR REPLACE FUNCTION ST_Buffer(text, float8, text)
RETURNS geometry AS
CREATE OR REPLACE FUNCTION ST_Intersection(geography, geography)
RETURNS geography
- AS 'SELECT geography(ST_Transform(ST_Intersection(ST_Transform(geometry($1), @extschema at ._ST_BestSRID($1, $2)), ST_Transform(geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
+ AS 'SELECT @extschema at .geography(@extschema at .ST_Transform(@extschema at .ST_Intersection(@extschema at .ST_Transform(@extschema at .geometry($1), @extschema at ._ST_BestSRID($1, $2)), @extschema at .ST_Transform(@extschema at .geometry($2), @extschema at ._ST_BestSRID($1, $2))), 4326))'
