[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
trac at osgeo.org
Thu Mar 22 11:21:02 PDT 2018
Reporter: tiiipponen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by strk):
2 and 3 would make sense as being a "minimum".
6 would be just arbitrary. Accuracy for an arc
really depends on the arc size.
6 segments on a 1e-15 degrees arc could be too much
(even 2 segments could be too much in that case).
If you want more segments in a circle we could
set not a minimum number of segments per arc but
per arc-or-quadrant. So if the minimum is 2 you
would have at least 8 segments for a ricle (2*4)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:22>
