[postgis-tickets] [PostGIS] #3719: Error: Invalid number of points in LinearRing
trac at osgeo.org
Fri Mar 23 02:54:39 PDT 2018
Reporter: tiiipponen | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by tiiipponen):
I actually mean with accuracy also that in many cases we use topological
queries like point in polygon and in many applications the point is
created near edge of the polygon. \\
For example with simple arithmetics we can see that \\
equilateral triangle inside circle covers 20.7% of the circle and \\
equilateral hexagon inside circle covers 82.7% of the circle. \\
By putting more segments, we help "point in polygon"-queries to get more
reliable results. And the same thing applies to polygons with short arcs
too. \\
Theoretically speaking... \\
This is maybe not problem in real world, but if there is no extra cost,
then why not.
And as you say, very short arcs needs same special handling if they have
six or two segments. And in our case, so short arcs are so rare, that they
can be edited away by hand if needed.
Putting this "per arc-or-quadrant" can be ok.
But as I said, you have freedom to do, what you think is easiest and best
way to do. It is ok to me.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3719#comment:23>
