[postgis-tickets] r16496 - change sorting of tickets to be nuermic by ticket number. Add in missing tickets
Regina Obe
lr at pcorp.us
Fri Mar 23 08:01:20 PDT 2018
Author: robe
Date: 2018-03-23 20:01:20 -0700 (Fri, 23 Mar 2018)
New Revision: 16496
branches/2.4/NEWS
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-03-24 02:17:06 UTC (rev 16495)
+++ branches/2.4/NEWS 2018-03-24 03:01:20 UTC (rev 16496)
@@ -2,21 +2,24 @@
2018/MM/DD
* Bug fixes *
+ - #3942, geojson: Do not include private header for json-c >= 0.13
+ (Björn Esser)
+ - #3952, ST_Transform fails in parallel mode (Paul Ramsey)
- #3978, Fix KNN when upgrading from 2.1 or older (Sandro Santilli)
+ - #4003, lwpoly_construct_circle: Avoid division by zero (Raúl Marín Rodríguez)
- #4004, Avoid memory exhaustion when building a btree index (Edmund Horner)
- - #4003, lwpoly_construct_circle: Avoid division by zero (Raúl Marín Rodríguez)
+ - #4016, proj 5.0.0 support (Raúl Marín Rodríguez)
+ - #4017, lwgeom lexer memory corruption (Peter E)
- #4020, Casting from box3d to geometry now returns correctly connected
PolyhedralSurface (Matthias Bay)
- - #3942, geojson: Do not include private header for json-c >= 0.13
- (Björn Esser)
- - #4025, Incorrect answers for temporally "amost overlapping" ranges
- - #4017, lwgeom lexer memory corruption (Peter E)
- - #4052, schema qualify several functions in geography
+ - #4025, Incorrect answers for temporally "almost overlapping" ranges
+ - #4052, schema qualify several functions in geography (Regina Obe)
+ - #4055, ST_ClusterIntersecting drops SRID (Daniel Baston)
* Enhancements *
+ - #3946, Compile support for PgSQL 11 (Paul Ramsey)
- #3992, Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect pkg-config
(Bas Couwenberg)
- - #3946, Support for PgSQL 11 (Paul Ramsey)
PostGIS 2.4.3
