[postgis-tickets] r16497 - Revise postgis extension helper functions to support PostgreSQL 11+ (proisagg replaced with prokind)
Regina Obe
lr at pcorp.us
Fri Mar 23 09:58:08 PDT 2018
Author: robe
Date: 2018-03-23 21:58:08 -0700 (Fri, 23 Mar 2018)
New Revision: 16497
trunk/extensions/postgis_extension_helper.sql
References #4044 for PostGIS 2.5 (trunk)
Modified: trunk/extensions/postgis_extension_helper.sql
--- trunk/extensions/postgis_extension_helper.sql 2018-03-24 03:01:20 UTC (rev 16496)
+++ trunk/extensions/postgis_extension_helper.sql 2018-03-24 04:58:08 UTC (rev 16497)
@@ -28,33 +28,56 @@
var_class text := '';
var_is_aggregate boolean := false;
var_sql_list text := '';
+ var_pgsql_version integer := CASE WHEN split_part(s,'.',1)::integer > 9 THEN split_part(s,'.',1) || '0' ELSE split_part(s,'.', 1) || split_part(s,'.', 2) END AS v
+ FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
BEGIN
var_class := CASE WHEN lower(param_type) = 'function' OR lower(param_type) = 'aggregate' THEN 'pg_proc' ELSE '' END;
var_is_aggregate := CASE WHEN lower(param_type) = 'aggregate' THEN true ELSE false END;
- var_sql_list := 'SELECT ''ALTER EXTENSION '' || e.extname || '' DROP '' || $3 || '' '' || COALESCE(proc.proname || ''('' || oidvectortypes(proc.proargtypes) || '')'',typ.typname, cd.relname, op.oprname,
- cs.typname || '' AS '' || ct.typname || '') '', opcname, opfname) || '';'' AS remove_command
- FROM pg_depend As d INNER JOIN pg_extension As e
- ON d.refobjid = e.oid INNER JOIN pg_class As c ON
- c.oid = d.classid
- LEFT JOIN pg_proc AS proc ON proc.oid = d.objid
- LEFT JOIN pg_type AS typ ON typ.oid = d.objid
- LEFT JOIN pg_class As cd ON cd.oid = d.objid
- LEFT JOIN pg_operator As op ON op.oid = d.objid
- LEFT JOIN pg_cast AS ca ON ca.oid = d.objid
- LEFT JOIN pg_type AS cs ON ca.castsource = cs.oid
- LEFT JOIN pg_type AS ct ON ca.casttarget = ct.oid
- LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
- LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
- WHERE d.deptype = ''e'' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;';
+ IF var_pgsql_version < 110 THEN
+ var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
+ cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
+ FROM pg_depend As d INNER JOIN pg_extension As e
+ ON d.refobjid = e.oid INNER JOIN pg_class As c ON
+ c.oid = d.classid
+ LEFT JOIN pg_proc AS proc ON proc.oid = d.objid
+ LEFT JOIN pg_type AS typ ON typ.oid = d.objid
+ LEFT JOIN pg_class As cd ON cd.oid = d.objid
+ LEFT JOIN pg_operator As op ON op.oid = d.objid
+ LEFT JOIN pg_cast AS ca ON ca.oid = d.objid
+ LEFT JOIN pg_type AS cs ON ca.castsource = cs.oid
+ LEFT JOIN pg_type AS ct ON ca.casttarget = ct.oid
+ LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
+ LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
+ WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
+ ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
+ c.oid = d.classid
+ WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a') = $4;$sql$;
+ END IF;
FOR var_r IN EXECUTE var_sql_list USING param_extension, var_class, param_type, var_is_aggregate
- LOOP
- var_sql := var_sql || var_r.remove_command || ';';
- END LOOP;
- IF var_sql > '' THEN
- EXECUTE var_sql;
- var_result := true;
- END IF;
- RETURN var_result;
+ LOOP
+ var_sql := var_sql || var_r.remove_command || ';';
+ END LOOP;
+ IF var_sql > '' THEN
+ EXECUTE var_sql;
+ var_result := true;
+ END IF;
+ RETURN var_result;
END;
LANGUAGE plpgsql VOLATILE;
