[postgis-tickets] [PostGIS] #4078: test_gdal_configured fails with GDAL 2.3.0-rc1
PostGIS trac at osgeo.org
Mon May 7 10:20:59 PDT 2018
  Reporter:  Bas Couwenberg  |      Owner:  pramsey
      Type:  defect          |     Status:  new
  Priority:  high            |  Milestone:  PostGIS 2.4.5
 Component:  postgis         |    Version:  2.4.x
Resolution:                  |   Keywords:
Comment (by rouault):
 Bas, I've just built Postgis trunk r16556 on a Debian testing with gdal
 2.3.0-rc1 from experimenta, and 'make check' in raster/test/cunit works
 fine.
 However I can reproduce the issue you have by setting GDAL_DATA to the
 empty string (contrary to not setting it at all), which must be
 interpreted by GADL as equivalent to the current directory, so I suspect
 that must be your issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4078#comment:4>
