[postgis-tickets] [PostGIS] #4081: ST_DWithin using spheroid does not calculate distance properly for geography
trac at osgeo.org
Tue May 8 14:01:10 PDT 2018
geography
Reporter: amc6 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.4.5
Component: postgis | Version: 2.4.x
Keywords: |
It appears that ST_DWithin is not properly calculating distance for
geography points. Or at the very least, it is not calculating distance the
same as ST_Distance does. (When forced to use a sphere, both ST_DWithin
and ST_Distance match.) I've included a query below to demonstrate the
problem. It includes several different calculations to illustrate what is
going on, but I will summarize the key points here:
The points are Point(1 2) and Point(1 1). According to a 3rd party
calculator (http://www.flymicro.com/records/distcalc.cfm) the distance
between these two points is 110575 meters and this matches with the
calculation produced by ST_Distance. ST_DWithin appears to be calculating
a value of around 111155.5 meters, which does not match the value
calculated by ST_Distance with either a spheroid or sphere. However, the
function _ST_DWithinUncached appears to be calculating the correct value
of 110575.
Query:
select ST_asEWKT(a), ST_asEWKT(b), pg_typeof(a), pg_typeof(b),
ST_Distance(a, b, true) as dist_true, ST_Distance(a, b, false) as
dist_false,
ST_DWithin(a, b, 111155.5, true) as within_111155_5_true, ST_DWithin(a, b,
111155.6, true) as within_111155_6_true,
ST_DWithin(a, b, 111195.079, false) as within_111195_079_false,
ST_DWithin(a, b, 111195.08, false) as within_111195_08_false,
_ST_DWithinUncached(a, b, 110576, true) as within_uncached_110576,
_ST_DWithinUncached(a, b, 110575, true) as within_uncached_110575,
_ST_DWithinUncached(a, b, 111195.08, false) as
within_uncached_111195_08_false, _ST_DWithinUncached(a, b, 111195.079,
false) as within_uncached_111195_079_false
from (
select ST_GeogFromText('SRID=4326;POINT(1.0 2.0)') as a,
ST_GeogFromText('SRID=4326;POINT(1.0 1.0)') as b
) as points
Results:
st_asewkt | st_asewkt | pg_typeof | pg_typeof |
dist_true | dist_false | within_111155_5_true |
within_111155_6_true | within_111195_079_false | within_111195_08_false |
within_uncached_110576 | within_uncached_110575 |
within_uncached_111195_08_false | within_uncached_111195_079_false
SRID=4326;POINT(1 2) | SRID=4326;POINT(1 1) | geography | geography |
110575.06481434 | 111195.07973463 | f | t
| f | t | t
| f | t | f
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4081>
