[postgis-tickets] r16567 - Updated docs and NEWS for various changes
Bborie Park
dustymugs at dspiral.net
Tue May 8 05:15:58 PDT 2018
Author: dustymugs
Date: 2018-05-08 17:15:57 -0700 (Tue, 08 May 2018)
New Revision: 16567
trunk/NEWS
trunk/doc/reference_raster.xml
Modified: trunk/NEWS
--- trunk/NEWS 2018-05-08 22:37:41 UTC (rev 16566)
+++ trunk/NEWS 2018-05-09 00:15:57 UTC (rev 16567)
@@ -15,6 +15,9 @@
- #4063, Optional false origin point for ST_Scale (Paul Ramsey)
- #4082, Add ST_BandFileSize and ST_BandFileTimestamp,
extend ST_BandMetadata (Even Rouault)
+ - #2597, Add ST_Grayscale (Bborie Park)
+ - #4007, Add ST_SetBandPath (Bborie Park)
+ - #4008, Add ST_SetBandIndex (Bborie Park)
* Breaking Changes *
- #4054, ST_SimplifyVW changed from > tolerance to >= tolerance
@@ -63,6 +66,9 @@
ST_DistanceCPA, and ST_CPAWithin (Paul Ramsey, Darafei Praliaskouski)
- #4071, ST_ClusterKMeans crash on NULL/EMPTY fixed (Darafei Praliaskouski)
- #4076, Reduce use of GEOS in topology implementation (Björn Harrtell)
+ - #4080, Add external raster band index to ST_BandMetaData
+ - Add Raster Tips section to Documentation for information about
+ Raster behavior (e.g. Out-DB performance, maximum open files)
PostGIS 2.4.0
2017/09/30
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml 2018-05-08 22:37:41 UTC (rev 16566)
+++ trunk/doc/reference_raster.xml 2018-05-09 00:15:57 UTC (rev 16567)
@@ -3779,8 +3779,7 @@
</para>
</note>
- <para>Enhanced: 2.5.0 to include filesize and filetimestamp for outdb rasters.</para>
+ <para>Enhanced: 2.5.0 to include <emphasis>outdbbandnum</emphasis>, <emphasis>filesize</emphasis> and <emphasis>filetimestamp</emphasis> for outdb rasters.</para>
</refsection>
<refsection>
@@ -3787,6 +3786,28 @@
<title>Examples: Variant 1</title>
<programlisting>
+SELECT
+ rid,
+ (foo.md).*
+FROM (
+ SELECT
+ rid,
+ ST_BandMetaData(rast, 1) AS md
+ FROM dummy_rast
+ WHERE rid=2
+) As foo;
+ rid | pixeltype | nodatavalue | isoutdb | path | outdbbandnum
+ 2 | 8BUI | 0 | f | |
+ </programlisting>
+ </refsection>
+ <refsection>
+ <title>Examples: Variant 2</title>
+ <programlisting>
WITH foo AS (
SELECT
ST_AddBand(NULL::raster, '/home/pele/devel/geo/postgis-git/raster/test/regress/loader/Projected.tif', NULL::int[]) AS rast
@@ -3807,28 +3828,6 @@
</refsection>
- <refsection>
- <title>Examples: Variant 2</title>
- <programlisting>
-SELECT
- rid,
- (foo.md).*
-FROM (
- SELECT
- rid,
- ST_BandMetaData(rast, 1) AS md
- FROM dummy_rast
- WHERE rid=2
-) As foo;
- rid | pixeltype | nodatavalue | isoutdb | path | outdbbandnum | filesize | filetimestamp |
- 2 | 8BUI | 0 | f | | | | |
- </programlisting>
- </refsection>
<!-- Optionally add a "See Also" section -->
<refsection>
<title>See Also</title>
