[postgis-tickets] r16578 - Fix PG 9.5 build in 2.4
Raul
raul at rmr.ninja
Mon May 21 03:41:33 PDT 2018
Author: algunenano
Date: 2018-05-21 03:41:32 -0700 (Mon, 21 May 2018)
New Revision: 16578
branches/2.4/NEWS
branches/2.4/extensions/address_standardizer/std_pg_hash.c
branches/2.4/libpgcommon/lwgeom_transform.c
References #4090
Applies the same fix as #3950
Closes https://github.com/postgis/postgis/pull/243
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2018-05-20 14:46:48 UTC (rev 16577)
+++ branches/2.4/NEWS 2018-05-21 10:41:32 UTC (rev 16578)
@@ -10,6 +10,7 @@
- #4070, use standard interruption error code on GEOS interruptions
(Paul Ramsey)
- #3980, delay freeing input until processing complete (lucasvr)
+ - #4090, PG 11 support (Paul Ramsey, Raúl Marín)
PostGIS 2.4.4
Modified: branches/2.4/extensions/address_standardizer/std_pg_hash.c
--- branches/2.4/extensions/address_standardizer/std_pg_hash.c 2018-05-20 14:46:48 UTC (rev 16577)
+++ branches/2.4/extensions/address_standardizer/std_pg_hash.c 2018-05-21 10:41:32 UTC (rev 16578)
@@ -113,7 +113,7 @@
static void
-#if POSTGIS_PGSQL_VERSION < 95
+#if POSTGIS_PGSQL_VERSION < 96
StdCacheDelete(MemoryContext context)
@@ -140,7 +140,7 @@
DeleteStdHashEntry(context);
static void
StdCacheInit(MemoryContext context)
@@ -194,7 +194,7 @@
#endif
-#endif /* POSTGIS_PGSQL_VERSION < 95 */
+#endif /* POSTGIS_PGSQL_VERSION < 96 */
uint32
@@ -383,7 +383,7 @@
DBG("Adding item to STD cache ('%s', '%s', '%s') index %d", lextab, gaztab, rultab, STDCache->NextSlot);
STDMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
&StdCacheContextMethods,
STDCache->StdCacheContext,
Modified: branches/2.4/libpgcommon/lwgeom_transform.c
--- branches/2.4/libpgcommon/lwgeom_transform.c 2018-05-20 14:46:48 UTC (rev 16577)
+++ branches/2.4/libpgcommon/lwgeom_transform.c 2018-05-21 10:41:32 UTC (rev 16578)
@@ -559,7 +559,7 @@
POSTGIS_DEBUGF(3, "adding SRID %d with proj4text \"%s\" to query cache at index %d", srid, proj_str, PROJ4Cache->PROJ4SRSCacheCount);
PJMemoryContext = MemoryContextCreate(T_AllocSetContext, 8192,
&PROJ4SRSCacheContextMethods,
PROJ4Cache->PROJ4SRSCacheContext,
