[postgis-tickets] [PostGIS] #4092: Logs unavailable in Dronie upon failure
PostGIS trac at osgeo.org
Mon May 21 08:06:52 PDT 2018
 Reporter:  Algunenano  |      Owner:  strk
     Type:  defect      |     Status:  assigned
 Priority:  medium      |  Milestone:  Management 2.0
Component:  buildbots   |    Version:
 Keywords:              |
 It seems that if the build fails Dronie isn't showing the build logs.
 Example build: https://drone.osgeo.org/postgis/postgis/1151
 Request URL: https://drone.osgeo.org/api/repos/postgis/postgis/logs/1151/1
 Request Method: GET
 Status Code: 404 Not Found
 Appears to be happening since https://drone.osgeo.org/postgis/postgis/1143
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4092>
