[postgis-tickets] [PostGIS] #4094: Failure to build with PG 11devel configured --with-llvm
trac at osgeo.org
Tue May 22 08:09:04 PDT 2018
Reporter: laurenz | Owner: strk
Type: patch | Status: new
Priority: medium | Milestone: PostGIS PostgreSQL
Component: build/upgrade/install | Version: trunk
Keywords: LLVM clang |
When PostgreSQL is configured `--with-llvm`, building PostGIS fails with:
/usr/lib64/ccache/clang -Wno-ignored-attributes -fno-strict-aliasing
-fwrapv -O2 -I/usr/include -I/usr/include/libxml2 -I/usr/include
-DHAVE_SFCGAL -I/usr/include/gdal "-I../../libpgcommon" -I../rt_core
-I. -I./ -I/home/laurenz/pg/include/postgresql/server
-I/home/laurenz/pg/include/postgresql/internal -D_GNU_SOURCE
-I/usr/include/libxml2 -flto=thin -emit-llvm -c -o rtpostgis.bc
rtpostgis.c
In file included from rtpostgis.c:138:
../../libpgcommon/lwgeom_pg.h:23:10: fatal error: 'liblwgeom.h' file not
found
#include "liblwgeom.h"
1 error generated.
make[2]: ***
[/home/laurenz/pg/lib/postgresql/pgxs/src/makefiles/../../src/Makefile.global:1009:
rtpostgis.bc] Error 1
make[2]: Leaving directory '/home/laurenz/postgis/raster/rt_pg'
make[1]: *** [Makefile:32: pglib] Error 2
make[1]: Leaving directory '/home/laurenz/postgis/raster'
make: *** [GNUmakefile:16: all] Error 1
The attached patch fixes the problem for me.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4094>
