[postgis-tickets] [PostGIS] #4095: Median fails robustness test on median
PostGIS trac at osgeo.org
Tue May 22 08:17:58 PDT 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.4.5
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 After this r16579
 I'm seeing on winnie's 32-bit 9.6 run so could be a 32-bit only issue.
 I'll try to rerun to see if the 64-bits exhibit similar issue
  Test: test_median_handles_3d_correctly ...passed
   Test: test_median_robustness ...make[2]: *** [Makefile:86: check]
 Segmentation fault
 make[2]: Leaving directory
 '/projects/postgis/branches/2.4/liblwgeom/cunit'
 make[1]: *** [Makefile:207: check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/2.4/liblwgeom'
 make: *** [GNUmakefile:16: check] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4095>
