[postgis-tickets] [PostGIS] #4095: Median fails robustness test on median
trac at osgeo.org
Tue May 22 10:25:28 PDT 2018
Reporter: robe | Owner: Algunenano
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.8
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Changes (by Algunenano):
* owner: pramsey => Algunenano
Comment:
I've been able to reproduce it in Ubuntu 17.04 (32bits):
293 if ( ! point->point || point->point->npoints < 1 )
(gdb) bt
#0 0xb7f5ba74 in lwpoint_is_empty (point=0x0) at lwpoint.c:293
#1 0xb7f5bb0a in lwpoint_getPoint3dz_p (point=0x0, out=0xbfffeeb8) at
lwpoint.c:49
#2 0x0804d320 in do_median_test (input=<optimized out>,
expected=<optimized out>) at cu_algorithm.c:1015
#3 0xb7ee1507 in ?? () from /usr/lib/i386-linux-gnu/libcunit.so.1
#4 0xb7ee1f76 in CU_run_test () from /usr/lib/i386-linux-
gnu/libcunit.so.1
#5 0x0804cd55 in main (argc=<optimized out>, argv=<optimized out>) at
cu_tester.c:216
I'll have a look tomorrow.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4095#comment:2>
