[postgis-tickets] [PostGIS] #4058: st_curvetoline hangs forever
trac at osgeo.org
Mon May 28 23:05:47 PDT 2018
Reporter: mjurce | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.5.0
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by strk):
Confirmed with r16553 - culprit is an arc with a very large radius,
resulting in a computed arc angle=0. I guess we'll want these arcs to be
rendered with a single segment:
DEBUG: [lwstroke.c:lwarc_linearize:156] lwarc_linearize called.
DEBUG: [lwstroke.c:lwarc_linearize:173] center is
POINT(-11241632062030.3 -11241633632176.3) - radius:1.58981e+13
DEBUG: [lwstroke.c:lwarc_linearize:250] lwarc_linearize: maxDiff:0.0001,
radius:1.58981e+13, halfAngle:0, increment:0 (0 degrees)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4058#comment:4>
