[postgis-tickets] r16597 - Fix typo in drawPoint() in doc images generator.
Darafei komzpa at gmail.com
Wed May 30 11:32:08 PDT 2018
Author: komzpa
Date: 2018-05-30 11:32:08 -0700 (Wed, 30 May 2018)
New Revision: 16597
   trunk/doc/html/image_src/generator.c
Issue introduced in r16296
Closes #4098
Closes https://github.com/postgis/postgis/pull/252
Modified: trunk/doc/html/image_src/generator.c
--- trunk/doc/html/image_src/generator.c	2018-05-29 08:06:15 UTC (rev 16596)
+++ trunk/doc/html/image_src/generator.c	2018-05-30 18:32:08 UTC (rev 16597)
@@ -114,7 +114,7 @@
 	lwprint_double(p.x, 10, x, OUT_DOUBLE_BUFFER_SIZE);
 	lwprint_double(p.y, 10, y1, OUT_DOUBLE_BUFFER_SIZE);
-	lwprint_double(p.y + styles->pointSize, 10, y1, OUT_DOUBLE_BUFFER_SIZE);
+	lwprint_double(p.y + styles->pointSize, 10, y2, OUT_DOUBLE_BUFFER_SIZE);
 	ptr += sprintf(ptr, "-fill %s -strokewidth 0 ", styles->pointColor);
 	ptr += sprintf(ptr, "-draw \"circle %s,%s %s,%s", x, y1, x, y2);
