[postgis-tickets] [PostGIS] #4186: Unable to upgrade from PostGIS 2.4.3 to 2.4.4
PostGIS trac at osgeo.org
Fri Nov 2 13:29:45 PDT 2018
  Reporter:  Rikiar      |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  blocker     |  Milestone:  PostGIS 2.4.6
 Component:  postgis     |    Version:  2.4.x
Resolution:  worksforme  |   Keywords:  Upgrade, 2.4.3
Comment (by msakrejdasfdc):
 Oh and another odd thing is that I tried a `CREATE OR REPLACE FUNCTION` on
 a dummy function with similar changes to the signature (i.e., only
 `parallel` and the schema-qualification of the return type changing), and
 both of those seem to `REPLACE` the original function just fine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4186#comment:8>
