[postgis-tickets] r16988 - Add missing schema qualifications for raster _ST_Intersects
Regina Obe
lr at pcorp.us
Wed Nov 7 07:37:43 PST 2018
Author: robe
Date: 2018-11-07 07:37:42 -0800 (Wed, 07 Nov 2018)
New Revision: 16988
trunk/raster/rt_pg/rtpostgis.sql.in
references #4129 for PostGIS 3.0
Modified: trunk/raster/rt_pg/rtpostgis.sql.in
--- trunk/raster/rt_pg/rtpostgis.sql.in 2018-11-07 15:08:22 UTC (rev 16987)
+++ trunk/raster/rt_pg/rtpostgis.sql.in 2018-11-07 15:37:42 UTC (rev 16988)
@@ -6417,18 +6417,18 @@
RETURNS boolean AS $$
DECLARE
hasnodata boolean := TRUE;
- _geom geometry;
+ _geom @extschema at .geometry;
BEGIN
- IF ST_SRID(rast) != ST_SRID(geom) THEN
+ IF @extschema at .ST_SRID(rast) != @extschema at .ST_SRID(geom) THEN
RAISE EXCEPTION 'Raster and geometry do not have the same SRID';
END IF;
- _geom := ST_ConvexHull(rast);
+ _geom := @extschema at .ST_ConvexHull(rast);
IF nband IS NOT NULL THEN
SELECT CASE WHEN bmd.nodatavalue IS NULL THEN FALSE ELSE NULL END INTO hasnodata FROM @extschema at .ST_BandMetaData(rast, nband) AS bmd;
END IF;
- IF ST_Intersects(geom, _geom) IS NOT TRUE THEN
+ IF @extschema at .ST_Intersects(geom, _geom) IS NOT TRUE THEN
RETURN FALSE;
ELSEIF nband IS NULL OR hasnodata IS FALSE THEN
RETURN TRUE;
