[postgis-tickets] r16991 - Schema qualify some missed calls in raster plpgsql/sql functions
Regina Obe lr at pcorp.us
Wed Nov 7 08:27:33 PST 2018
Author: robe
Date: 2018-11-07 08:27:33 -0800 (Wed, 07 Nov 2018)
New Revision: 16991
   branches/2.5/NEWS
   branches/2.5/raster/rt_pg/rtpostgis.sql.in
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2018-11-07 15:41:34 UTC (rev 16990)
+++ branches/2.5/NEWS	2018-11-07 16:27:33 UTC (rev 16991)
@@ -15,6 +15,7 @@
   - #4217, Fix ST_Subdivide crash on EMPTY in intermediate iterations (Darafei
     Praliaskouski)
   - #4223, ST_DistanceTree error for near parallel boxes (Paul Ramsey)
+  - Schema qualify more functions for raster (Regina Obe)
 PostGIS 2.5.0
Modified: branches/2.5/raster/rt_pg/rtpostgis.sql.in
--- branches/2.5/raster/rt_pg/rtpostgis.sql.in	2018-11-07 15:41:34 UTC (rev 16990)
+++ branches/2.5/raster/rt_pg/rtpostgis.sql.in	2018-11-07 16:27:33 UTC (rev 16991)
@@ -6290,16 +6290,16 @@
 		tile integer[];
 		edge integer[];
 	BEGIN
-		IF NOT ST_SameAlignment(rast, coverage) THEN
+		IF NOT @extschema at .ST_SameAlignment(rast, coverage) THEN
 			RAISE NOTICE 'Raster and coverage are not aligned';
 			RETURN FALSE;
 		END IF;
-		_rastmeta := ST_Metadata(rast);
-		_covmeta := ST_Metadata(coverage);
+		_rastmeta := @extschema at .ST_Metadata(rast);
+		_covmeta := @extschema at .ST_Metadata(coverage);
 		-- get coverage grid coordinates of upper-left of rast
-		cr := ST_WorldToRasterCoord(coverage, _rastmeta.upperleftx, _rastmeta.upperlefty);
+		cr := @extschema at .ST_WorldToRasterCoord(coverage, _rastmeta.upperleftx, _rastmeta.upperlefty);
 		-- rast is not part of coverage
 		IF
@@ -6417,18 +6417,18 @@
 	RETURNS boolean AS $$
 	DECLARE
 		hasnodata boolean := TRUE;
-		_geom geometry;
+		_geom @extschema at .geometry;
 	BEGIN
-		IF ST_SRID(rast) != ST_SRID(geom) THEN
+		IF @extschema at .ST_SRID(rast) != @extschema at .ST_SRID(geom) THEN
 			RAISE EXCEPTION 'Raster and geometry do not have the same SRID';
 		END IF;
-		_geom := ST_ConvexHull(rast);
+		_geom := @extschema at .ST_ConvexHull(rast);
 		IF nband IS NOT NULL THEN
 			SELECT CASE WHEN bmd.nodatavalue IS NULL THEN FALSE ELSE NULL END INTO hasnodata FROM @extschema at .ST_BandMetaData(rast, nband) AS bmd;
 		END IF;
-		IF ST_Intersects(geom, _geom) IS NOT TRUE THEN
+		IF @extschema at .ST_Intersects(geom, _geom) IS NOT TRUE THEN
 			RETURN FALSE;
 		ELSEIF nband IS NULL OR hasnodata IS FALSE THEN
 			RETURN TRUE;
@@ -6443,7 +6443,7 @@
 -- This function can not be STRICT
 CREATE OR REPLACE FUNCTION st_intersects(geom geometry, rast raster, nband integer DEFAULT NULL)
 	RETURNS boolean AS
-	$$ SELECT $1 OPERATOR(@extschema at .&&) $2::geometry AND @extschema at ._st_intersects($1, $2, $3); $$
+	$$ SELECT $1 OPERATOR(@extschema at .&&) $2::@extschema at .geometry AND @extschema at ._st_intersects($1, $2, $3); $$
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL
 	COST 1000;
@@ -6453,13 +6453,13 @@
 CREATE OR REPLACE FUNCTION st_intersects(rast raster, geom geometry, nband integer DEFAULT NULL)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) $2 AND @extschema at ._st_intersects($2, $1, $3) $$
+	AS $$ SELECT $1::@extschema at .geometry OPERATOR(@extschema at .&&) $2 AND @extschema at ._st_intersects($2, $1, $3) $$
 	COST 1000;
 CREATE OR REPLACE FUNCTION st_intersects(rast raster, nband integer, geom geometry)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) $3 AND @extschema at ._st_intersects($3, $1, $2) $$
+	AS $$ SELECT $1::@extschema at .geometry OPERATOR(@extschema at .&&) $3 AND @extschema at ._st_intersects($3, $1, $2) $$
 	COST 1000;
@@ -6629,7 +6629,7 @@
 CREATE OR REPLACE FUNCTION ST_DWithin(rast1 raster, nband1 integer, rast2 raster, nband2 integer, distance double precision)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($3), $5) AND $3::geometry OPERATOR(@extschema at .&&) ST_Expand(ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._ST_dwithin(st_convexhull($1), st_convexhull($3), $5) ELSE @extschema at ._ST_dwithin($1, $2, $3, $4, $5) END $$
+	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($3), $5) AND $3::@extschema at .geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._ST_dwithin(@extschema at .st_convexhull($1), @extschema at .st_convexhull($3), $5) ELSE @extschema at ._ST_dwithin($1, $2, $3, $4, $5) END $$
 	COST 1000;
@@ -6651,7 +6651,7 @@
 CREATE OR REPLACE FUNCTION ST_DFullyWithin(rast1 raster, nband1 integer, rast2 raster, nband2 integer, distance double precision)
 	RETURNS boolean
-	AS $$ SELECT $1::geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($3), $5) AND $3::geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._ST_DFullyWithin(@extschema at .ST_ConvexHull($1), @extschema at .ST_Convexhull($3), $5) ELSE @extschema at ._ST_DFullyWithin($1, $2, $3, $4, $5) END $$
+	AS $$ SELECT $1::@extschema at .geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($3), $5) AND $3::@extschema at .geometry OPERATOR(@extschema at .&&) @extschema at .ST_Expand(@extschema at .ST_ConvexHull($1), $5) AND CASE WHEN $2 IS NULL OR $4 IS NULL THEN @extschema at ._ST_DFullyWithin(@extschema at .ST_ConvexHull($1), @extschema at .ST_Convexhull($3), $5) ELSE @extschema at ._ST_DFullyWithin($1, $2, $3, $4, $5) END $$
 	COST 1000;
@@ -6686,7 +6686,7 @@
 	DECLARE
 		intersects boolean := FALSE;
 	BEGIN
-		intersects := ST_Intersects(geomin, rast, band);
+		intersects := @extschema at .ST_Intersects(geomin, rast, band);
 		IF intersects THEN
 			-- Return the intersections of the geometry with the vectorized parts of
 			-- the raster and the values associated with those parts, if really their
@@ -6697,12 +6697,12 @@
 					val
 				FROM (
 					SELECT
-						ST_Intersection((gv).geom, geomin) AS intgeom,
+						@extschema at .ST_Intersection((gv).geom, geomin) AS intgeom,
 						(gv).val
-					FROM ST_DumpAsPolygons(rast, band) gv
-					WHERE ST_Intersects((gv).geom, geomin)
+					FROM @extschema at .ST_DumpAsPolygons(rast, band) gv
+					WHERE @extschema at .ST_Intersects((gv).geom, geomin)
 				) foo
-				WHERE NOT ST_IsEmpty(intgeom);
+				WHERE NOT @extschema at .ST_IsEmpty(intgeom);
 		ELSE
 			-- If the geometry does not intersect with the raster, return an empty
 			-- geometry and a null value
@@ -6710,7 +6710,7 @@
 				SELECT
 					emptygeom,
 					NULL::float8
-				FROM ST_GeomCollFromText('GEOMETRYCOLLECTION EMPTY', ST_SRID($1)) emptygeom;
+				FROM @extschema at .ST_GeomCollFromText('GEOMETRYCOLLECTION EMPTY', ST_SRID($1)) emptygeom;
 		END IF;
 	END;
@@ -6781,7 +6781,7 @@
 	nodataval double precision
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, $2, $3, $4, $5, ARRAY[$6, $6]) $$
+	$$ SELECT @extschema at .st_intersection($1, $2, $3, $4, $5, ARRAY[$6, $6]) $$
 	LANGUAGE 'sql' IMMUTABLE _PARALLEL;
 CREATE OR REPLACE FUNCTION st_intersection(
@@ -6790,7 +6790,7 @@
 	nodataval double precision[]
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', $5) $$
+	$$ SELECT @extschema at .st_intersection($1, $2, $3, $4, 'BOTH', $5) $$
@@ -6799,7 +6799,7 @@
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, $2, $3, $4, 'BOTH', ARRAY[$5, $5]) $$
+	$$ SELECT @extschema at .st_intersection($1, $2, $3, $4, 'BOTH', ARRAY[$5, $5]) $$
 -- Variants without band number
@@ -6810,7 +6810,7 @@
 	nodataval double precision[] DEFAULT NULL
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, 1, $2, 1, $3, $4) $$
+	$$ SELECT @extschema at .st_intersection($1, 1, $2, 1, $3, $4) $$
@@ -6820,7 +6820,7 @@
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, 1, $2, 1, $3, ARRAY[$4, $4]) $$
+	$$ SELECT @extschema at .st_intersection($1, 1, $2, 1, $3, ARRAY[$4, $4]) $$
@@ -6829,7 +6829,7 @@
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', $3) $$
+	$$ SELECT @extschema at .st_intersection($1, 1, $2, 1, 'BOTH', $3) $$
@@ -6838,7 +6838,7 @@
 	RETURNS raster AS
-	$$ SELECT st_intersection($1, 1, $2, 1, 'BOTH', ARRAY[$3, $3]) $$
+	$$ SELECT @extschema at .st_intersection($1, 1, $2, 1, 'BOTH', ARRAY[$3, $3]) $$
@@ -7057,7 +7057,7 @@
 	exclude_nodata_value boolean DEFAULT TRUE
 	RETURNS double precision
-	AS $$ SELECT st_nearestvalue($1, $2, st_setsrid(st_makepoint(st_rastertoworldcoordx($1, $3, $4), st_rastertoworldcoordy($1, $3, $4)), st_srid($1)), $5) $$
+	AS $$ SELECT @extschema at .st_nearestvalue($1, $2, @extschema at .st_setsrid(@extschema at .st_makepoint(@extschema at .st_rastertoworldcoordx($1, $3, $4), @extschema at .st_rastertoworldcoordy($1, $3, $4)), @extschema at .st_srid($1)), $5) $$
 	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
 CREATE OR REPLACE FUNCTION st_nearestvalue(
@@ -7066,7 +7066,7 @@
-	AS $$ SELECT st_nearestvalue($1, 1, st_setsrid(st_makepoint(st_rastertoworldcoordx($1, $2, $3), st_rastertoworldcoordy($1, $2, $3)), st_srid($1)), $4) $$
+	AS $$ SELECT @extschema at .st_nearestvalue($1, 1, @extschema at .st_setsrid(@extschema at .st_makepoint(@extschema at .st_rastertoworldcoordx($1, $2, $3), @extschema at .st_rastertoworldcoordy($1, $2, $3)), @extschema at .st_srid($1)), $4) $$
@@ -7116,11 +7116,11 @@
 		wy double precision;
 		rtn double precision[][];
 	BEGIN
-		IF (st_geometrytype($3) != 'ST_Point') THEN
+		IF (@extschema at .st_geometrytype($3) != 'ST_Point') THEN
 			RAISE EXCEPTION 'Attempting to get the neighbor of a pixel with a non-point geometry';
 		END IF;
-		IF ST_SRID(rast) != ST_SRID(pt) THEN
+		IF @extschema at .ST_SRID(rast) != @extschema at .ST_SRID(pt) THEN
 		END IF;
@@ -7129,8 +7129,8 @@
 		SELECT @extschema at ._ST_neighborhood(
 			$1, $2,
-			st_worldtorastercoordx(rast, wx, wy),
-			st_worldtorastercoordy(rast, wx, wy),
+			@extschema at .st_worldtorastercoordx(rast, wx, wy),
+			@extschema at .st_worldtorastercoordy(rast, wx, wy),
 			$4, $5,
 			$6
 		) INTO rtn;
@@ -7145,7 +7145,7 @@
 	RETURNS double precision[][]
-	AS $$ SELECT st_neighborhood($1, 1, $2, $3, $4, $5) $$
+	AS $$ SELECT @extschema at .st_neighborhood($1, 1, $2, $3, $4, $5) $$
@@ -7238,7 +7238,7 @@
 		cn := 'enforce_srid_' || $3;
-		sql := 'SELECT st_srid('
+		sql := 'SELECT @extschema at .st_srid('
 			|| quote_ident($3)
 			|| ') FROM ' || fqtn
 			|| ' LIMIT 1';
@@ -7252,7 +7252,7 @@
 		sql := 'ALTER TABLE ' || fqtn
 			|| ' ADD CONSTRAINT ' || quote_ident(cn)
-			|| ' CHECK (st_srid('
+			|| ' CHECK (@extschema at .st_srid('
 			|| quote_ident($3)
 			|| ') = ' || attr || ')';
@@ -7318,7 +7318,7 @@
 		cn := 'enforce_scale' || $4 || '_' || $3;
-		sql := 'SELECT st_scale' || $4 || '('
+		sql := 'SELECT @extschema at .st_scale' || $4 || '('
 			|| quote_ident($3)
 			|| ') FROM '
 			|| fqtn
@@ -7333,7 +7333,7 @@
-			|| ' CHECK (round(st_scale' || $4 || '('
+			|| ' CHECK (round(@extschema at .st_scale' || $4 || '('
 			|| quote_ident($3)
 			|| ')::numeric, 10) = round(' || text(attr) || '::numeric, 10))';
 		RETURN  @extschema at ._add_raster_constraint(cn, sql);
@@ -7596,7 +7596,7 @@
 		sql := 'ALTER TABLE ' || fqtn ||
 			' ADD CONSTRAINT ' || quote_ident(cn) ||
-			' EXCLUDE ((' || quote_ident($3) || '::geometry) WITH =)';
+			' EXCLUDE ((' || quote_ident($3) || '::@extschema at .geometry) WITH =)';
 	END;
 	$$ LANGUAGE 'plpgsql' VOLATILE STRICT
@@ -7690,7 +7690,7 @@
 			END IF;
 			-- remove band
-			_covrast := ST_MakeEmptyRaster(_covrast);
+			_covrast := @extschema at .ST_MakeEmptyRaster(_covrast);
 		EXCEPTION WHEN OTHERS THEN
 			RAISE NOTICE 'Unable to create coverage raster. Cannot add coverage tile constraint: % (%)',
         SQLERRM, SQLSTATE;
@@ -7862,7 +7862,7 @@
-			|| ' CHECK (_raster_constraint_pixel_types(' || quote_ident($3)
+			|| ' CHECK (@extschema at ._raster_constraint_pixel_types(' || quote_ident($3)
 		FOR x in 1..max LOOP
 			sql := sql || '"' || attr[x] || '"';
@@ -8992,7 +8992,7 @@
   ipy FLOAT8;
   tx int;
   ty int;
-  te GEOMETRY; -- tile extent
+  te @extschema at .GEOMETRY; -- tile extent
   ncols int;
   nlins int;
   srid int;
@@ -9002,17 +9002,17 @@
   RAISE DEBUG 'Target coverage will have sfx=%, sfy=%', sfx, sfy;
   -- 2. Loop over each target tile and build it from source tiles
-  ipx := st_xmin(ext);
+  ipx := @extschema at .st_xmin(ext);
   ncols := ceil((st_xmax(ext)-ipx)/sfx/tw);
   IF sfy < 0 THEN
-    ipy := st_ymax(ext);
-    nlins := ceil((st_ymin(ext)-ipy)/sfy/th);
+    ipy := @extschema at .st_ymax(ext);
+    nlins := ceil((@extschema at .st_ymin(ext)-ipy)/sfy/th);
   ELSE
-    ipy := st_ymin(ext);
-    nlins := ceil((st_ymax(ext)-ipy)/sfy/th);
+    ipy := @extschema at .st_ymin(ext);
+    nlins := ceil((@extschema at .st_ymax(ext)-ipy)/sfy/th);
   END IF;
-  srid := ST_Srid(ext);
+  srid := @extschema at .ST_Srid(ext);
   RAISE DEBUG 'Target coverage will have % x % tiles, each of approx size % x %', ncols, nlins, tw, th;
   RAISE DEBUG 'Target coverage will cover extent %', ext::box2d;
@@ -9019,7 +9019,7 @@
   FOR tx IN 0..ncols-1 LOOP
     FOR ty IN 0..nlins-1 LOOP
-      te := ST_MakeEnvelope(ipx + tx     *  tw  * sfx,
+      te := @extschema at .ST_MakeEnvelope(ipx + tx     *  tw  * sfx,
                              ipy + ty     *  th  * sfy,
                              ipx + (tx+1) *  tw  * sfx,
                              ipy + (ty+1) *  th  * sfy,
@@ -9093,7 +9093,7 @@
   ttab := 'o_' || factor || '_' || sinfo.tab;
   sql := 'CREATE TABLE ' || quote_ident(sinfo.sch)
       || '.' || quote_ident(ttab)
-      || ' AS SELECT ST_Retile($1, $2, $3, $4, $5, $6, $7) '
+      || ' AS SELECT @extschema at .ST_Retile($1, $2, $3, $4, $5, $6, $7) '
       || quote_ident(col);
   EXECUTE sql USING tab, col, sinfo.ext,
                     sinfo.sfx * factor, sinfo.sfy * factor,
@@ -9121,7 +9121,7 @@
         rh int;                -- raster height (may change at edges)
         x int;                 -- x index of coverage
         y int;                 -- y index of coverage
-        template raster;       -- an empty template raster, where each cell
+        template @extschema at .raster;       -- an empty template raster, where each cell
                                -- represents a tile in the coverage
         minY double precision;
         maxX double precision;
