[postgis-tickets] [PostGIS] #4223: ST_Distance returns 0 instead of 5
trac at osgeo.org
Wed Nov 7 09:15:59 PST 2018
Reporter: br0ke | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.5.1
Component: postgis | Version: 2.5.x
Resolution: fixed | Keywords:
Comment (by pramsey):
In [changeset:"16993" 16993]:
#!CommitTicketReference repository="" revision="16993"
Patch over bad behaviour for near-parallel boxes and distancetree.
Unfortunately, this "fix" is probably breakable, just put the boxes closer
and closer together until we get "close enough to be the same" results
from the edge normal comparison again. Only way around this is to do dot
product and comparisons in higher-than-double space
References #4223
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4223#comment:6>
