[postgis-tickets] r16996 - Documentation for AddRasterConstraint optional parameters
Darafei
komzpa at gmail.com
Wed Nov 7 10:56:40 PST 2018
Author: komzpa
Date: 2018-11-07 22:56:40 -0800 (Wed, 07 Nov 2018)
New Revision: 16996
trunk/NEWS
trunk/doc/reference_raster.xml
Patch by Sunveer Singh
Closes #2767
Closes https://github.com/postgis/postgis/pull/325
Modified: trunk/NEWS
--- trunk/NEWS 2018-11-07 17:56:00 UTC (rev 16995)
+++ trunk/NEWS 2018-11-08 06:56:40 UTC (rev 16996)
@@ -29,6 +29,7 @@
- #4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)
- #4155, Support for GEOMETRYCOLLECTION, POLYGON, TIN, TRIANGLE in
ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)
+ - #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
PostGIS 2.5.0
2018/09/23
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml 2018-11-07 17:56:00 UTC (rev 16995)
+++ trunk/doc/reference_raster.xml 2018-11-08 06:56:40 UTC (rev 16996)
@@ -452,26 +452,26 @@
<paramdef><type>name </type>
<parameter>rastcolumn</parameter></paramdef>
- <paramdef><type>boolean </type>
- <parameter>srid</parameter></paramdef>
+ <paramdef choice="opt"><type>boolean </type>
+ <parameter>srid=true</parameter></paramdef>
- <parameter>scale_x</parameter></paramdef>
+ <parameter>scale_x=true</parameter></paramdef>
- <parameter>scale_y</parameter></paramdef>
+ <parameter>scale_y=true</parameter></paramdef>
- <parameter>blocksize_x</parameter></paramdef>
+ <parameter>blocksize_x=true</parameter></paramdef>
- <parameter>blocksize_y</parameter></paramdef>
+ <parameter>blocksize_y=true</parameter></paramdef>
- <parameter>same_alignment</parameter></paramdef>
+ <parameter>same_alignment=true</parameter></paramdef>
- <parameter>regular_blocking</parameter></paramdef>
+ <parameter>regular_blocking=false</parameter></paramdef>
<parameter>num_bands=true</parameter>
@@ -489,7 +489,6 @@
<parameter>extent=true</parameter>
</paramdef>
</funcprototype>
<funcprototype>
<funcdef>boolean <function>AddRasterConstraints</function></funcdef>
