[postgis-tickets] r16997 - Documentation for AddRasterConstraint optional parameters
Darafei
komzpa at gmail.com
Wed Nov 7 10:57:59 PST 2018
Author: komzpa
Date: 2018-11-07 22:57:59 -0800 (Wed, 07 Nov 2018)
New Revision: 16997
branches/2.5/NEWS
branches/2.5/doc/reference_raster.xml
Patch by Sunveer Singh
Closes #2767
Closes https://github.com/postgis/postgis/pull/325
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-11-08 06:56:40 UTC (rev 16996)
+++ branches/2.5/NEWS 2018-11-08 06:57:59 UTC (rev 16997)
@@ -17,6 +17,7 @@
- #4223, ST_DistanceTree error for near parallel boxes (Paul Ramsey)
- Schema qualify more functions for raster (Regina Obe)
- #4216, Revert non-sliced box access (Paul Ramsey)
+ - #2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
PostGIS 2.5.0
Modified: branches/2.5/doc/reference_raster.xml
--- branches/2.5/doc/reference_raster.xml 2018-11-08 06:56:40 UTC (rev 16996)
+++ branches/2.5/doc/reference_raster.xml 2018-11-08 06:57:59 UTC (rev 16997)
@@ -452,26 +452,26 @@
<paramdef><type>name </type>
<parameter>rastcolumn</parameter></paramdef>
- <paramdef><type>boolean </type>
- <parameter>srid</parameter></paramdef>
+ <paramdef choice="opt"><type>boolean </type>
+ <parameter>srid=true</parameter></paramdef>
- <parameter>scale_x</parameter></paramdef>
+ <parameter>scale_x=true</parameter></paramdef>
- <parameter>scale_y</parameter></paramdef>
+ <parameter>scale_y=true</parameter></paramdef>
- <parameter>blocksize_x</parameter></paramdef>
+ <parameter>blocksize_x=true</parameter></paramdef>
- <parameter>blocksize_y</parameter></paramdef>
+ <parameter>blocksize_y=true</parameter></paramdef>
- <parameter>same_alignment</parameter></paramdef>
+ <parameter>same_alignment=true</parameter></paramdef>
- <parameter>regular_blocking</parameter></paramdef>
+ <parameter>regular_blocking=false</parameter></paramdef>
<parameter>num_bands=true</parameter>
@@ -489,7 +489,6 @@
<parameter>extent=true</parameter>
</paramdef>
</funcprototype>
<funcprototype>
<funcdef>boolean <function>AddRasterConstraints</function></funcdef>
