[postgis-tickets] [PostGIS] #2835: ST_SetValues doc should specify 1-indexing for column/row parameters
PostGIS trac at osgeo.org
Fri Nov 9 08:22:44 PST 2018
  Reporter:  strk           |      Owner:  robe
      Type:  enhancement    |     Status:  new
  Priority:  medium         |  Milestone:
 Component:  documentation  |    Version:  2.1.x
Resolution:                 |   Keywords:  raster
Comment (by strk):
 You can verify what the ticket description says (that argument refers
 to first element with 1 instead of 0), then provide a patch for the
 documentation. Note you can also provide coordinates for pulling your
 changes from a git repository, possibly by using a fork of one of
 PostGIS' CodeMirrors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2835#comment:2>
