[postgis-tickets] [PostGIS] #2835: ST_SetValues doc should specify 1-indexing for column/row parameters
trac at osgeo.org
Sat Nov 10 11:20:15 PST 2018
Reporter: strk | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone:
Component: documentation | Version: 2.1.x
Resolution: | Keywords: raster
Comment (by komzpa):
sunveersingh,
it is much like the previous issue you fixed! let's start a bit earlier in
the process this time:
1. go https://github.com/postgis/postgis/tree/svn-trunk/doc
2. find file that mentions ST_SetValues inside
3. edit it, so it is clear from text that row and column are 1-indexed
4. provide a pull request with change.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2835#comment:3>
