[postgis-tickets] r17004 - ST_Scale: Document the availability of the origin parameter
Raul raul at rmr.ninja
Mon Nov 12 01:16:09 PST 2018
Author: algunenano
Date: 2018-11-12 01:16:08 -0800 (Mon, 12 Nov 2018)
New Revision: 17004
   trunk/doc/reference_editor.xml
Closes #4232
Modified: trunk/doc/reference_editor.xml
--- trunk/doc/reference_editor.xml	2018-11-12 09:15:35 UTC (rev 17003)
+++ trunk/doc/reference_editor.xml	2018-11-12 09:16:08 UTC (rev 17004)
@@ -1652,7 +1652,8 @@
 		<para>Availability: 1.1.0.</para>
 		<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
-		<para>Enhanced: 2.2.0 support for scaling all dimension (geometry parameter) was introduced.</para>
+                <para>Enhanced: 2.2.0 support for scaling all dimension (<varname>factor</varname> parameter) was introduced.</para>
+                <para>Enhanced: 2.5.0 support for scaling relative to a local origin (<varname>origin</varname> parameter) was introduced.</para>
 		<para>&P_support;</para>
 		<para>&Z_support;</para>
 		<para>&curve_support;</para>
