[postgis-tickets] [PostGIS] #4233: Undefined behaviour in gserialized_spgist_picksplit_nd (CREATE INDEX)
trac at osgeo.org
Mon Nov 12 08:08:20 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
Detected running test `regress_spgist_index_nd` with `-fsanitize=undefined
-fsanitize-undefined-trap-on-error`:
Core was generated by `postgres: raul postgis_reg [local] CREATE IN'.
Program terminated with signal SIGILL, Illegal instruction.
#0 0x00007ff58cf98e8f in gserialized_spgist_picksplit_nd
(fcinfo=0x7ffc205e4f60) at gserialized_spgist_nd.c:335
335 if (GIDX_GET_MAX(box, i) != FLT_MAX)
(gdb) bt
#1 0x000056216c80ee51 in FunctionCall2Coll (flinfo=0x7ff5f56a515c,
collation=1, arg1=33, arg2=33) at fmgr.c:1145
#2 0x000056216c3f07c9 in doPickSplit (index=<optimized out>,
state=<optimized out>, current=<optimized out>, parent=<optimized out>,
newLeafTuple=<optimized out>, level=<optimized out>,
isNulls=<optimized out>, isNew=<optimized out>) at spgdoinsert.c:829
#3 spgdoinsert (index=<optimized out>, state=<optimized out>,
heapPtr=0x56216dd7cefc, datum=140694363145508, isnull=false)
at spgdoinsert.c:2077
#4 0x000056216c3ec6c9 in spgistBuildCallback (index=0x7ff58d1e31f0,
htup=<optimized out>, values=0x7ffc205e58e0, isnull=0x7ffc205e58c0,
tupleIsAlive=<optimized out>, state=0x7ffc205e5a80) at spginsert.c:57
#5 0x000056216c4374fe in IndexBuildHeapRangeScan
(heapRelation=0x7ff58d1d0d30, indexRelation=0x7ff58d1e31f0,
indexInfo=0x56216dd7c950,
allow_sync=<optimized out>, anyvisible=false, start_blockno=<optimized
out>, numblocks=4294967295,
callback=0x56216c3ec680 <spgistBuildCallback>,
callback_state=0x7ffc205e5a80, scan=0x56216dd7ceb0) at index.c:2944
#6 0x000056216c436d53 in IndexBuildHeapScan (heapRelation=0x56216dcf6401,
indexRelation=0x1, indexInfo=0x21, allow_sync=33,
callback=0x7ff5f56a515c, callback_state=0x56216dbcd010, scan=0x0) at
index.c:2458
Does
https://github.com/postgis/postgis/blob/126b97b077a1ee512a6de71931fb04de58546154/postgis/gserialized_spgist_nd.c#L335
need to use `j` instead of `i`? If so, let's consider using a more
descriptive name (`tupleIterator`, `dimension`...).
Related to #4230
Tested with PG11 and Postgis trunk.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4233>
