[postgis-tickets] [PostGIS] #4240: Getting segmentation faults
trac at osgeo.org
Sun Nov 18 00:30:45 PST 2018
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.1
Component: postgis | Version: 2.5.x
Keywords: |
This might be just my computer not seeing the same issue on bots.
My pg log shows this
2018-11-18 00:21:20.010 EST [5172] ERROR: Number of iterations must be
between 1 and 5 : LWGEOM_ChaikinSmoothing
2018-11-18 00:21:20.010 EST [5172] STATEMENT: SELECT '2',
ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)',10));
2018-11-18 00:21:20.010 EST [5172] STATEMENT: SELECT '3',
ST_astext(ST_ChaikinSmoothing('LINESTRING(0 0, 8 8, 0 16)',0));
2018-11-18 00:21:21.090 EST [14872] LOG: could not receive data from
client: An existing connection was forcibly closed by the remote host.
I tried against both mingw and VC++ build and I'm getting segmentation
faults all over the place.
subdivide ..sh: line 1: 4500 Segmentation fault psql -v
"VERBOSITY=terse" -v
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_117_tmp'"
-v
"scriptdir=C:/MING64~1/projects/POSTGR~1/rel/PG11W6~2/share/contrib/postgis-2.5"
-v "regdir=/projects/postgis/branches/2.5/regress" -tXA postgis_reg <
subdivide.sql > /projects/postgis/tmp/2.5_pg11w64/test_117_out 2>&1
failed (diff expected obtained:
/projects/postgis/tmp/2.5_pg11w64/test_117_diff)
voronoi .. ok
minimum_clearance .. ok
oriented_envelope .. ok
regress_brin_index ..sh: line 1: 12568 Segmentation fault psql -v
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_121_tmp'"
-v
regress_brin_index.sql > /projects/postgis/tmp/2.5_pg11w64/test_121_out
2>&1
/projects/postgis/tmp/2.5_pg11w64/test_121_diff)
regress_brin_index_3d ..sh: line 1: 14820 Segmentation fault psql -v
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_122_tmp'"
-v
regress_brin_index_3d.sql > /projects/postgis/tmp/2.5_pg11w64/test_122_out
2>&1
/projects/postgis/tmp/2.5_pg11w64/test_122_diff)
regress_brin_index_geography ..sh: line 1: 5328 Segmentation fault
psql -v "VERBOSITY=terse" -v
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_123_tmp'"
-v
regress_brin_index_geography.sql >
/projects/postgis/tmp/2.5_pg11w64/test_123_out 2>&1
/projects/postgis/tmp/2.5_pg11w64/test_123_diff)
regress_spgist_index_2d ..sh: line 1: 8904 Segmentation fault psql
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_124_tmp'"
-v
regress_spgist_index_2d.sql >
/projects/postgis/tmp/2.5_pg11w64/test_124_out 2>&1
/projects/postgis/tmp/2.5_pg11w64/test_124_diff)
regress_spgist_index_3d ..sh: line 1: 10132 Segmentation fault psql
"tmpfile='/projects/postgis/tmp/2.5_pg11w64/pgis_reg_tmp//test_125_tmp'"
-v
regress_spgist_index_3d.sql >
/projects/postgis/tmp/2.5_pg11w64/test_125_out 2>&1
/projects/postgis/tmp/2.5_pg11w64/test_125_diff)
Anyway I'll investigate further - might just be something up with my pc.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4240>
