[postgis-tickets] [PostGIS] #4242: Getting compile error on winnie
PostGIS trac at osgeo.org
Sun Nov 18 01:39:30 PST 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.5.1
Component:  postgis  |    Version:  2.4.x
 Keywords:           |
 Seems this has been going on for over a month.
 *** Warning: Linking the executable cu_tester against the loadable module
 *** libSFCGAL.dll is not portable!
 libtool: link: x86_64-w64-mingw32-gcc -Wall -fno-omit-frame-pointer -Wall
 -Wmissing-prototypes -IE:/jenkins/geos/rel-3.7.0w64gcc48/include
 -I/projects/proj/rel-4.9.3w64gcc48/include
 -I/projects/postgresql/rel/pg11w64gcc48/include -I/projects/rel-
 libiconv-1.13.1w64gcc48/include -I.. -I/projects/CGAL/rel-
 sfcgal-1.3.2w64gcc48/include -DHAVE_SFCGAL -o .libs/cu_tester
 cu_algorithm.o cu_bytebuffer.o cu_buildarea.o cu_clean.o cu_print.o
 cu_minimum_bounding_circle.o cu_misc.o cu_ptarray.o cu_geodetic.o
 cu_geos.o cu_geos_cluster.o cu_tree.o cu_measures.o cu_effectivearea.o
 cu_chaikin.o cu_filterm.o cu_node.o cu_clip_by_rect.o cu_libgeom.o
 cu_lwstroke.o cu_split.o cu_stringbuffer.o cu_triangulate.o
 cu_homogenize.o cu_force_sfs.o cu_out_twkb.o cu_out_wkt.o cu_out_wkb.o
 cu_out_gml.o cu_out_kml.o cu_out_geojson.o cu_out_svg.o
 cu_out_encoded_polyline.o cu_surface.o cu_out_x3d.o cu_in_geojson.o
 cu_in_twkb.o cu_in_wkb.o cu_in_wkt.o cu_in_encoded_polyline.o
 cu_iterator.o cu_varint.o cu_unionfind.o cu_wrapx.o cu_tester.o
 cu_sfcgal.o  ../.libs/liblwgeom.a
 -L/projects/postgresql/rel/pg11w64gcc48/lib
 -L/projects/gdal/rel-2.2.4w64gcc48/lib -L/projects/rel-
 libiconv-1.13.1w64gcc48/lib -LE:/jenkins/geos/rel-3.7.0w64gcc48/lib
 -L/projects/proj/rel-4.9.3w64gcc48/lib
 -L/projects/json-c/rel-0.12w64gcc48/lib -L/projects/CGAL/rel-
 sfcgal-1.3.2w64gcc48/lib
 /projects/proj/rel-4.9.3w64gcc48/lib/libproj.dll.a -lpthread
 /projects/json-c/rel-0.12w64gcc48/lib/libjson-c.a -lgeos_c
 /mingw/x86_64-w64-mingw32/lib/libcunit.a
 -L/sources/CUnit-2.1-2/CUnit/Sources E:/jenkins/CGAL/rel-
 sfcgal-1.3.2w64gcc48/lib/libSFCGAL.dll
 -L/projects/json-c/rel-0.12w64gcc48/lib -LE:/jenkins/CGAL/rel-
 Makefile:88: recipe for target 'check' failed
 make[2]: *** [check] Error 127
 make[2]: Leaving directory
 '/projects/postgis/branches/2.5/liblwgeom/cunit'
 Makefile:204: recipe for target 'check' failed
 make[1]: *** [check] Error 2
 make[1]: Leaving directory '/projects/postgis/branches/2.5/liblwgeom'
 GNUmakefile:16: recipe for target 'check' failed
 make: *** [check] Error 1
 Note sure what changed, guess I'll revert back to 2.5.1dev until I sort
 this one out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4242>
