[postgis-tickets] [PostGIS] #4243: Use of deprecated function in tickets
PostGIS trac at osgeo.org
Sun Nov 18 15:21:16 PST 2018
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_diff)
 --- tickets_expected    2018-11-08 12:15:17.205801173 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_out
 2018-11-18 23:17:32.358030529 +0000
 @@ -125,8 +125,8 @@
 #696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
  #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
 11028513.63)
  #723|0101000020e61000006284f068e33826c00000000000004440
 -#723|0107000020e610000000000000
 +#723|0101000020e6100000000000000000f87f000000000000f87f
  #723|0101000020e61000006284f068e33826c00100000000804b40
  #804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
 srsDimension="2">0 0</gml:pos></gml:Point>
  #845|t
 @@ -205,8 +205,8 @@
  ERROR:  invalid SRID: 999000 not found in spatial_ref_sys
  #1596.5|3395
  NOTICE:  SRID value -1 converted to the officially unknown SRID value 0
 -#1596.6|public.road_pg.roads_geom SRID changed to 0
 -#1596.7|0
 +ERROR:  function postgis_constraint_srid(name, character varying,
 character varying) does not exist at character 8
 +#1596.7|3395
  #1596|Point[GS]
  #1695|MULTIPOLYGON EMPTY
  #1697.1|0
 oops after I took out functions marked for deprecation in  r17029, ran
 into this issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4243>
