[postgis-tickets] [PostGIS] #4231: PostGIS can't build with PostgreSQL v12devel because "pg_constraint.consrc" has been removed
trac at osgeo.org
Sun Nov 18 15:57:16 PST 2018
has been removed
Reporter: Laurenz Albe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.5.2
Component: postgis | Version: 2.5.x
Resolution: | Keywords:
Comment (by robe):
In [changeset:"17030" 17030]:
#!CommitTicketReference repository="" revision="17030"
Put back deprecated functions removed in r17029, but patch them to use
newer pg_get_constraintdef function.
Also mark them as undeprecated cause they are used in other management
functions, and it's too messy to change those to use teh raw sql.
We maybe stuck with these forever :(
Closes #4243 for PostGIS 3.0
Also fix error in raster patching
References #4231 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4231#comment:4>
