[postgis-tickets] [PostGIS] #4245: Debbie failing on all runs of postgis 3.0
PostGIS trac at osgeo.org
Mon Nov 19 20:25:05 PST 2018
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.0.0
Component:  buildbots  |    Version:  2.4.x
 Keywords:             |
 Even after the postgrsql 12 fix, debbie is still failing.  But it seems
 this change is affecting all postgres branches, not just the 12.  The 12
 install issues were fixed.
 Loading PostGIS into 'postgis_reg'
   /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
 install/share/contrib/postgis/postgis.sql
 install/share/contrib/postgis/postgis_comments.sql
 install/share/contrib/postgis/postgis_proc_set_search_path.sql
 PostgreSQL 11.1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.2.0-9)
 8.2.0, 64-bit
   Postgis 3.0.0dev - r17032 - 2018-11-19 01:43:53
   scripts 3.0.0dev r17032
   GEOS: 3.8.0dev-CAPI-1.12.0 70a9773c
   PROJ: Rel. 5.2.0, September 15th, 2018
  tickets .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_diff)
 --- tickets_expected    2018-11-08 12:15:17.205801173 +0000
 +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_out
 2018-11-19 16:33:01.165535816 +0000
 @@ -125,8 +125,8 @@
 #696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
  #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
 11028513.63)
  #723|0101000020e61000006284f068e33826c00000000000004440
 -#723|0107000020e610000000000000
 +#723|0101000020e6100000000000000000f87f000000000000f87f
  #723|0101000020e61000006284f068e33826c00100000000804b40
  #804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
 srsDimension="2">0 0</gml:pos></gml:Point>
  #845|t
 I'm not sure how my fix for #4231 or if its just some other chagnes going
 on.
 I haven't patched 2.5 yet with 12 fix, will see if that blows up too when
 Ido.  That one is passing at the moment.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4245>
