[postgis-tickets] [PostGIS] #4245: Debbie tickets regress on geography intersects failing on all PostgreSQL branches for postgis 3.0 (was: Debbie failing on all runs of postgis 3.0)
trac at osgeo.org
Mon Nov 19 20:30:17 PST 2018
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: buildbots | Version: 2.4.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> Even after the postgrsql 12 fix, debbie is still failing. But it seems
> this change is affecting all postgres branches, not just the 12. The 12
> install issues were fixed.
> Loading PostGIS into 'postgis_reg'
> /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-
> install/share/contrib/postgis/postgis.sql
> install/share/contrib/postgis/postgis_comments.sql
> install/share/contrib/postgis/postgis_proc_set_search_path.sql
> PostgreSQL 11.1 on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.2.0-9)
> 8.2.0, 64-bit
> Postgis 3.0.0dev - r17032 - 2018-11-19 01:43:53
> scripts 3.0.0dev r17032
> GEOS: 3.8.0dev-CAPI-1.12.0 70a9773c
> PROJ: Rel. 5.2.0, September 15th, 2018
> tickets .. failed (diff expected obtained:
> /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_diff)
> --- tickets_expected 2018-11-08 12:15:17.205801173 +0000
> +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_95_out
> 2018-11-19 16:33:01.165535816 +0000
> @@ -125,8 +125,8 @@
> #696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
> #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
> 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
> 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
> 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
> 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
> 11028513.63)
> #723|0101000020e61000006284f068e33826c00000000000004440
> -#723|0107000020e610000000000000
> +#723|0101000020e6100000000000000000f87f000000000000f87f
> #723|0101000020e61000006284f068e33826c00100000000804b40
> #804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
> srsDimension="2">0 0</gml:pos></gml:Point>
> #845|t
> I'm not sure how my fix for #4231 or if its just some other chagnes going
> on.
> I haven't patched 2.5 yet with 12 fix, will see if that blows up too when
> Ido. That one is passing at the moment.
New description:
The test triggering the difference is
SELECT '#723',
encode(ST_AsEWKB(ST_SnapToGrid( ST_Intersection(a.geog,
b.geog)::geometry, 0.00001),'ndr'),'hex')
FROM (VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ),
(ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') ) ) As a(geog) CROSS
JOIN ( VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ),
(ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') )) As b(geog);
8.2.0, 64-bit
@@ -125,8 +125,8 @@
11028513.63)
#845|t
on.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4245#comment:1>
