[postgis-tickets] [PostGIS] #4244: Travis: Enable UBSan checks in CI
trac at osgeo.org
Thu Nov 22 05:56:08 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
PR adding clang UBsan checks: https://github.com/postgis/postgis/pull/337
Thanks to Kompzpa for the help adding Clang to the docker image.
Pending:
- Have a Docker image that compiles Postgresql with clang so clang's ubsan
is also run in the extension code (the part using PGXS). This would also
be useful in case we want to debug JIT issues, as currently gcc is being
used.
- Fix topology undefined behaviour alerts: I might revisit it at some
point in the future, but I find other warnings (memory sanitizer) more
interesting right now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4244#comment:3>
