[postgis-tickets] [PostGIS] #4251: topology failing on PostgreSQL 12devel
trac at osgeo.org
Thu Nov 22 09:12:34 PST 2018
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.5.2
Component: topology | Version: 2.4.x
Keywords: |
regress/legacy_predicate .. failed (diff expected obtained:
/var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_2_diff)
--- regress/legacy_predicate_expected 2018-09-16 16:55:15.018504025
+0000
+++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg12w64/test_2_out
2018-11-22 07:43:13.490101967 +0000
@@ -5,116 +5,75 @@
26
COMMIT
BEGIN
-1
-2
-3
+ERROR: syntax error at or near "oids" at character 80
+ERROR: syntax error at or near "oids" at character 81
+ERROR: current transaction is aborted, commands ignored until end of
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
transaction block
COMMIT
-4
-features.big_parcels.the_geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
-5
-6
-features.big_signs.the_geom SRID:0 TYPE:MULTIPOINT DIMS:2
+ERROR: relation "features.land_parcels" does not exist at character 13
+ERROR: relation "features.traffic_signs" does not exist at character 13
+ERROR: relation "features.city_streets" does not exist at character 13
+ERROR: syntax error at or near "OIDS" at character 78
+ERROR: schema "features" does not exist
+ERROR: Schema 'features' is not a valid schemaname
+ERROR: relation "features.big_parcels" does not exist at character 13
+ERROR: relation "features.big_streets" does not exist at character 13
+ERROR: syntax error at or near "OIDS" at character 76
+ERROR: relation "features.big_signs" does not exist at character 13
BEGIN
topology is still failing for 12 for topoology even after adding the
pg_constraint fix
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4251>
