[postgis-tickets] r17060 - Add 2.2.8 to upgrade targets
Regina Obe
lr at pcorp.us
Thu Nov 22 01:10:51 PST 2018
Author: robe
Date: 2018-11-22 13:10:50 -0800 (Thu, 22 Nov 2018)
New Revision: 17060
branches/2.5/NEWS
branches/2.5/extensions/upgradeable_versions.mk
branches/2.5/postgis/postgis.sql.in
branches/2.5/raster/rt_pg/rtpostgis.sql.in
branches/2.5/topology/topology.sql.in
Remove using of pg_constraint.consrc to allow support of 12 as noted by Laurenz Albe (pg_constraint.consrc was removed in 12devel)
Closes #4231 for postgis 2.5.2
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-11-22 16:18:14 UTC (rev 17059)
+++ branches/2.5/NEWS 2018-11-22 21:10:50 UTC (rev 17060)
@@ -2,6 +2,8 @@
XXXX/XX/XX
* Bug fixes *
+ - #4231, Support for PostgreSQL 12dev (remove use of pg_constraint.consrc)
+ (Regina Obe, Laurenz Albe)
- #4247, Avoid undefined behaviour in next_float functions (Raúl Marín)
- #4249, Fix undefined behaviour in raster intersection (Raúl Marín)
- #4246, Fix undefined behaviour in ST_3DDistance (Raúl Marín)
Modified: branches/2.5/extensions/upgradeable_versions.mk
--- branches/2.5/extensions/upgradeable_versions.mk 2018-11-22 16:18:14 UTC (rev 17059)
+++ branches/2.5/extensions/upgradeable_versions.mk 2018-11-22 21:10:50 UTC (rev 17060)
@@ -25,6 +25,7 @@
2.2.5 \
2.2.6 \
2.2.7 \
+ 2.2.8 \
2.3.0 \
2.3.1 \
2.3.2 \
Modified: branches/2.5/postgis/postgis.sql.in
--- branches/2.5/postgis/postgis.sql.in 2018-11-22 16:18:14 UTC (rev 17059)
+++ branches/2.5/postgis/postgis.sql.in 2018-11-22 21:10:50 UTC (rev 17060)
@@ -5554,11 +5554,14 @@
LANGUAGE 'sql' STABLE STRICT _PARALLEL;
-- Availability: 2.0.0
--- Deprecation in 2.2.0
+-- Undeprecated 2.5.2 needed by UpdateGeometrySRID
CREATE OR REPLACE FUNCTION postgis_constraint_dims(geomschema text, geomtable text, geomcolumn text) RETURNS integer AS
SELECT replace(split_part(s.consrc, ' = ', 2), ')', '')::integer
- FROM pg_class c, pg_namespace n, pg_attribute a, pg_constraint s
+ FROM pg_class c, pg_namespace n, pg_attribute a
+ , (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+ FROM pg_constraint) AS s
WHERE n.nspname = $1
AND c.relname = $2
AND a.attname = $3
@@ -5573,11 +5576,15 @@
-- support function to pull out geometry type from constraint check
-- will return pretty name instead of ugly name
+-- Undeprecated
+-- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
CREATE OR REPLACE FUNCTION postgis_constraint_type(geomschema text, geomtable text, geomcolumn text) RETURNS varchar AS
SELECT replace(split_part(s.consrc, '''', 2), ')', '')::varchar
AND c.relname = $2
AND a.attname = $3
@@ -5593,6 +5600,7 @@
-- Changed: 2.1.8 significant performance improvement for constraint based columns
-- Changed: 2.2.0 get rid of schema, table, column cast to improve performance
-- Changed: 2.4.0 List also Parent partitioned tables
CREATE OR REPLACE VIEW geometry_columns AS
SELECT current_database()::character varying(256) AS f_table_catalog,
n.nspname AS f_table_schema,
@@ -5608,7 +5616,8 @@
LEFT JOIN ( SELECT s.connamespace,
s.conrelid,
s.conkey, replace(split_part(s.consrc, ''''::text, 2), ')'::text, ''::text) As type
- FROM pg_constraint AS s
+ FROM (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
WHERE s.consrc ~~* '%geometrytype(% = %'::text
) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
@@ -5615,7 +5624,8 @@
s.conrelid,
s.conkey, replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text)::integer As ndims
WHERE s.consrc ~~* '%ndims(% = %'::text
) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
@@ -5622,7 +5632,8 @@
s.conrelid,
s.conkey, replace(replace(split_part(s.consrc, ' = '::text, 2), ')'::text, ''::text), '('::text, ''::text)::integer As srid
WHERE s.consrc ~~* '%srid(% = %'::text
) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
Modified: branches/2.5/raster/rt_pg/rtpostgis.sql.in
--- branches/2.5/raster/rt_pg/rtpostgis.sql.in 2018-11-22 16:18:14 UTC (rev 17059)
+++ branches/2.5/raster/rt_pg/rtpostgis.sql.in 2018-11-22 21:10:50 UTC (rev 17060)
@@ -7210,7 +7210,9 @@
'[\(\)]', '', 'g'
)::integer
AND c.relname = $2
AND a.attname = $3
@@ -7280,7 +7282,9 @@
'[ ''''\(\)]', '', 'g'
)::text AS val
AND c.relname = $2
AND a.attname = $3
@@ -7366,7 +7370,9 @@
'[\(\)]', '', 'g'
)::integer
END
AND c.relname = $2
AND a.attname = $3
@@ -7442,7 +7448,9 @@
RETURNS geometry AS $$
SELECT
trim(both '''' from split_part(trim(split_part(s.consrc, ' @ ', 2)), '::', 1))::geometry
AND c.relname = $2
AND a.attname = $3
@@ -7504,7 +7512,9 @@
RETURNS boolean AS $$
SELECT
TRUE
AND c.relname = $2
AND a.attname = $3
@@ -7545,7 +7555,7 @@
sql := 'ALTER TABLE ' || fqtn ||
' ADD CONSTRAINT ' || quote_ident(cn) ||
- ' CHECK (st_samealignment(' || quote_ident($3) || ', ''' || attr || '''::raster))';
+ ' CHECK (@extschema at .st_samealignment(' || quote_ident($3) || ', ''' || attr || '''::raster))';
RETURN @extschema at ._add_raster_constraint(cn, sql);
END;
$$ LANGUAGE 'plpgsql' VOLATILE STRICT
@@ -7561,7 +7571,10 @@
SELECT
TRUE
- FROM pg_class c, pg_namespace n, pg_attribute a, pg_constraint s, pg_index idx, pg_operator op
+ , (SELECT connamespace, conrelid, conindid, conkey, contype, conexclop, pg_get_constraintdef(oid) As consrc
+ , pg_index idx, pg_operator op
AND c.relname = $2
AND a.attname = $3
@@ -7609,7 +7622,10 @@
BEGIN
SELECT
s.conname INTO cn
+ , (SELECT connamespace, conname, conrelid, conkey, conindid, contype, conexclop, pg_get_constraintdef(oid) As consrc
AND c.relname = $2
AND a.attname = $3
@@ -7632,7 +7648,9 @@
SELECT
TRUE
AND c.relname = $2
AND a.attname = $3
@@ -7743,7 +7761,9 @@
'[\(\)]', '', 'g'
)::integer
AND c.relname = $2
AND a.attname = $3
@@ -7810,7 +7830,9 @@
'::', 1
)::text[]
AND c.relname = $2
AND a.attname = $3
@@ -7893,7 +7915,9 @@
'::', 1
)::double precision[]
AND c.relname = $2
AND a.attname = $3
@@ -7982,7 +8006,9 @@
'::', 1
)::boolean[]
AND c.relname = $2
AND a.attname = $3
@@ -8624,7 +8650,9 @@
split_part(split_part(s.consrc, '''::name', 2), '''', 2)::name,
split_part(split_part(s.consrc, '''::name', 3), '''', 2)::name,
trim(both from split_part(s.consrc, ',', 2))::integer
AND c.relname = $2
AND a.attname = $3
@@ -8694,7 +8722,8 @@
pg_attribute a,
pg_type t,
pg_namespace n,
- pg_constraint s
+ (SELECT connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
WHERE t.typname = 'raster'::name
AND a.attisdropped = false
AND a.atttypid = t.oid
Modified: branches/2.5/topology/topology.sql.in
--- branches/2.5/topology/topology.sql.in 2018-11-22 16:18:14 UTC (rev 17059)
+++ branches/2.5/topology/topology.sql.in 2018-11-22 21:10:50 UTC (rev 17060)
@@ -829,7 +829,8 @@
--c.consrc src,
regexp_matches(c.consrc,
'\.topology_id = (\d+).*\.layer_id = (\d+).*\.type = (\d+)') inf
- FROM pg_constraint c, pg_class r, pg_namespace n
+ FROM (SELECT conname, connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+ FROM pg_constraint) AS c, pg_class r, pg_namespace n
WHERE c.conname LIKE 'check_topogeom_%'
AND r.oid = c.conrelid
AND n.oid = r.relnamespace
