[postgis-tickets] r17049 - Replace pg_constraint.consrc for pg_get_constraintdef fix for topology
Regina Obe lr at pcorp.us
Wed Nov 21 11:33:52 PST 2018
Author: robe
Date: 2018-11-21 23:33:52 -0800 (Wed, 21 Nov 2018)
New Revision: 17049
   trunk/topology/topology.sql.in
References #4231 for PostGIS 3.0.0
Modified: trunk/topology/topology.sql.in
--- trunk/topology/topology.sql.in	2018-11-22 06:46:54 UTC (rev 17048)
+++ trunk/topology/topology.sql.in	2018-11-22 07:33:52 UTC (rev 17049)
@@ -829,7 +829,8 @@
     --c.consrc src,
     regexp_matches(c.consrc,
       '\.topology_id = (\d+).*\.layer_id = (\d+).*\.type = (\d+)') inf
-  FROM pg_constraint c, pg_class r, pg_namespace n
+  FROM (SELECT conname, connamespace, conrelid, conkey, pg_get_constraintdef(oid) As consrc
+		    FROM pg_constraint) AS c, pg_class r, pg_namespace n
   WHERE c.conname LIKE 'check_topogeom_%'
     AND r.oid = c.conrelid
     AND n.oid = r.relnamespace
