[postgis-tickets] [PostGIS] #4251: topology failing on PostgreSQL 12devel because oids removed
PostGIS trac at osgeo.org
Fri Nov 23 09:56:23 PST 2018
  Reporter:  robe      |      Owner:  robe
      Type:  defect    |     Status:  closed
  Priority:  blocker   |  Milestone:  PostGIS 2.5.2
 Component:  topology  |    Version:  2.4.x
Resolution:  fixed     |   Keywords:
Changes (by robe):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17063" 17063]:
 #!CommitTicketReference repository="" revision="17063"
 Get rid of use of oids in topology regress was taken out in PostgreSQL 12.
 Closes #4251 for PostGIS 2.5.2
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4251#comment:5>
