[postgis-tickets] r17077 - [doc] Let people know about EWKT in UpdateGeometrySRID
Darafei
komzpa at gmail.com
Mon Nov 26 08:31:20 PST 2018
Author: komzpa
Date: 2018-11-26 08:31:20 -0800 (Mon, 26 Nov 2018)
New Revision: 17077
trunk/doc/reference_management.xml
Closes #4224
Modified: trunk/doc/reference_management.xml
--- trunk/doc/reference_management.xml 2018-11-25 19:36:07 UTC (rev 17076)
+++ trunk/doc/reference_management.xml 2018-11-26 16:31:20 UTC (rev 17077)
@@ -1136,16 +1136,23 @@
</refsection>
<refsection>
<title>Examples</title>
- <para>This will change the srid of the roads table to 4326 from whatever it was before</para>
+ <para>Insert geometries into roads table with a SRID set already using <link linkend="ST_GeomFromEWKT">EWKT format</link>:</para>
+ <programlisting>COPY roads (geom) FROM STDIN;
+SRID=4326;LINESTRING(0 0, 10 10)
+SRID=4326;LINESTRING(10 10, 15 0)
+ </programlisting>
+ <para>This will change the srid of the roads table to 4326 from whatever it was before:</para>
<programlisting>SELECT UpdateGeometrySRID('roads','geom',4326);</programlisting>
- <para>The prior example is equivalent to this DDL statement</para>
+ <para>The prior example is equivalent to this DDL statement:</para>
<programlisting>ALTER TABLE roads
ALTER COLUMN geom TYPE geometry(MULTILINESTRING, 4326)
USING ST_SetSRID(geom,4326);</programlisting>
- <para>If you got the projection wrong (or brought it in as unknown) in load and you wanted to transform to web mercator all in one shot
- You can do this with
+ <para>If you got the projection wrong (or brought it in as unknown) in load and you wanted to transform to web mercator all in one shot you can do this with
DDL but there is no equivalent PostGIS management function to do so in one go.</para>
ALTER COLUMN geom TYPE geometry(MULTILINESTRING, 3857) USING ST_Transform(ST_SetSRID(geom,4326),3857) ;</programlisting>
@@ -1156,7 +1163,8 @@
<para>
<xref linkend="RT_UpdateRasterSRID"/>,
<xref linkend="ST_SetSRID"/>,
- <xref linkend="ST_Transform"/>
+ <xref linkend="ST_Transform"/>,
+ <xref linkend="ST_GeomFromEWKT"/>
</para>
</refsection>
</refentry>
