[postgis-tickets] [PostGIS] #4259: PostGIS 2.5 unable to compile with GDAL 2.3
PostGIS trac at osgeo.org
Mon Nov 26 10:16:56 PST 2018
 Reporter:  nstires       |      Owner:  pramsey
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 2.5.2
Component:  postgis       |    Version:  2.5.x
 Keywords:  postgis gdal  |
 I'm attempting to build PostGIS 2.5 with the GDAL 2.3 libraries. It seems
 to require GDALv1 however. I saw that there's GDALv2 support on Windows
 however. I was unable to find a previous ticket that referenced the same
 issue.
 [root at build rpm]# cat /etc/centos-release
 CentOS release 6.10 (Final)
 [root at build rpm]# java -version
 openjdk version "1.8.0_181"
 OpenJDK Runtime Environment (build 1.8.0_181-b13)
 OpenJDK 64-Bit Server VM (build 25.181-b13, mixed mode)
 [root at build rpm]# gdalinfo --version
 GDAL 2.3.2, released 2018/09/21
 [root at build rpm]# gcc --version
 gcc (GCC) 4.8.2 20140120 (Red Hat 4.8.2-15)
 Copyright (C) 2013 Free Software Foundation, Inc.
 This is free software; see the source for copying conditions.  There is NO
 warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
 PURPOSE.
 [root at build rpm]# g++ --version
 g++ (GCC) 4.8.2 20140120 (Red Hat 4.8.2-15)
 PURPOSE.
 [root at build rpm]# ll /usr/lib
 total 57444
 drwxr-xr-x. 3 root root     4096 Sep 17 14:05 anaconda-runtime
 drwxr-xr-x. 5 root root     4096 Sep 17 14:52 ConsoleKit
 dr-xr-xr-x. 2 root root     4096 Sep 23  2011 games
 drwxr-xr-x. 3 root root     4096 Jun 19 08:10 gcc
 drwxr-xr-x. 2 root root     4096 May 10  2016 java
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.3.1
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.4.0
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.4.1
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.4.2
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.5.0
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.6.0
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.7.0
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-1.8.0
 drwxr-xr-x. 2 root root     4096 May 10  2016 java-ext
 drwxr-xr-x. 5 root root     4096 Sep 17 14:52 jvm
 drwxr-xr-x. 2 root root     4096 May 10  2016 jvm-commmon
 drwxr-xr-x. 5 root root     4096 Sep 17 14:52 jvm-exports
 drwxr-xr-x. 5 root root     4096 Sep 17 14:52 jvm-private
 -rw-r--r--. 1 root root 30521472 Oct 11 15:33 libgdal.a
 -rwxr-xr-x. 1 root root   523008 Oct 11 15:33 libgdalalljni.so
 lrwxrwxrwx. 1 root root       13 Nov 26 12:20 libgdalalljni.so.20 ->
 libgdaljni.so
 lrwxrwxrwx. 1 root root       16 Nov 26 12:20 libgdaljni.so ->
 libgdalalljni.so
 -rwxr-xr-x. 1 root root     1032 Oct 11 15:33 libgdal.la
 lrwxrwxrwx. 1 root root       17 Nov 26 12:20 libgdal.so ->
 libgdal.so.20.4.2
 lrwxrwxrwx. 1 root root       17 Nov 26 12:20 libgdal.so.20 ->
 libgdal.so.20.4.2
 -rwxr-xr-x. 1 root root 15799072 Oct 11 15:33 libgdal.so.20.4.2
 -rwxr-xr-x. 1 root root  5934696 Oct 11 15:33 libltidsdk.so
 -rwxr-xr-x. 1 root root  5934696 Oct 11 15:33 libltidsdk.so.9
 dr-xr-xr-x. 2 root root     4096 Sep 17 14:26 locale
 drwxr-xr-x. 2 root root     4096 Nov 26 12:20 pkgconfig
 drwxr-xr-x. 3 root root     4096 Aug 18  2016 python2.6
 drwxr-xr-x. 4 root root     4096 Sep 17 14:29 rpm
 drwxr-xr-x. 4 root root     4096 Sep 17 14:30 ruby
 lrwxrwxrwx. 1 root root       30 Sep 17 14:26 sendmail ->
 /etc/alternatives/mta-sendmail
 lrwxrwxrwx. 1 root root       24 Sep 17 14:26 sendmail.postfix ->
 ../sbin/sendmail.postfix
 drwxr-xr-x. 2 root root     4096 Mar 22  2017 yum-plugins
 [root at build postgis25-2.5.1]# ./configure --with-
 pgconfig=/usr/pgsql-9.6/bin/pg_config
 checking for a BSD-compatible install... /usr/bin/install -c
 checking build system type... x86_64-pc-linux-gnu
 checking host system type... x86_64-pc-linux-gnu
 checking how to print strings... printf
 checking for gcc... gcc
 checking whether the C compiler works... yes
 checking for C compiler default output file name... a.out
 checking for suffix of executables...
 checking whether we are cross compiling... no
 checking for suffix of object files... o
 checking whether we are using the GNU C compiler... yes
 checking whether gcc accepts -g... yes
 checking for gcc option to accept ISO C89... none needed
 checking for a sed that does not truncate output... /bin/sed
 checking for grep that handles long lines and -e... /bin/grep
 checking for egrep... /bin/grep -E
 checking for fgrep... /bin/grep -F
 checking for ld used by gcc...
 /opt/rh/devtoolset-2/root/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/ld
 checking if the linker (/opt/rh/devtoolset-2/root/usr/libexec/gcc/x86_64
 -redhat-linux/4.8.2/ld) is GNU ld... yes
 checking for BSD- or MS-compatible name lister (nm)...
 /opt/rh/devtoolset-2/root/usr/bin/nm -B
 checking the name lister (/opt/rh/devtoolset-2/root/usr/bin/nm -B)
 interface... BSD nm
 checking whether ln -s works... yes
 checking the maximum length of command line arguments... 1966080
 checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-
 gnu format... func_convert_file_noop
 checking how to convert x86_64-pc-linux-gnu file names to toolchain
 checking for /opt/rh/devtoolset-2/root/usr/libexec/gcc/x86_64-redhat-
 linux/4.8.2/ld option to reload object files... -r
 checking for objdump... objdump
 checking how to recognize dependent libraries... pass_all
 checking for dlltool... no
 checking how to associate runtime and link libraries... printf %s\n
 checking for ar... ar
 checking for archiver @FILE support... @
 checking for strip... strip
 checking for ranlib... ranlib
 checking for gawk... gawk
 checking command to parse /opt/rh/devtoolset-2/root/usr/bin/nm -B output
 from gcc object... ok
 checking for sysroot... no
 checking for a working dd... /bin/dd
 checking how to truncate binary pipes... /bin/dd bs=4096 count=1
 checking for mt... no
 checking if : is a manifest tool... no
 checking how to run the C preprocessor... gcc -E
 checking for ANSI C header files... yes
 checking for sys/types.h... yes
 checking for sys/stat.h... yes
 checking for stdlib.h... yes
 checking for string.h... yes
 checking for memory.h... yes
 checking for strings.h... yes
 checking for inttypes.h... yes
 checking for stdint.h... yes
 checking for unistd.h... yes
 checking for dlfcn.h... yes
 checking for objdir... .libs
 checking if gcc supports -fno-rtti -fno-exceptions... no
 checking for gcc option to produce PIC... -fPIC -DPIC
 checking if gcc PIC flag -fPIC -DPIC works... yes
 checking if gcc static flag -static works... no
 checking if gcc supports -c -o file.o... yes
 checking if gcc supports -c -o file.o... (cached) yes
 checking whether the gcc linker
 (/opt/rh/devtoolset-2/root/usr/libexec/gcc/x86_64-redhat-linux/4.8.2/ld -m
 elf_x86_64) supports shared libraries... yes
 checking whether -lc should be explicitly linked in... no
 checking dynamic linker characteristics... GNU/Linux ld.so
 checking how to hardcode library paths into programs... immediate
 checking whether stripping libraries is possible... yes
 checking if libtool supports shared libraries... yes
 checking whether to build shared libraries... yes
 checking whether to build static libraries... yes
 checking for gcc... (cached) gcc
 checking whether we are using the GNU C compiler... (cached) yes
 checking whether gcc accepts -g... (cached) yes
 checking for gcc option to accept ISO C89... (cached) none needed
 checking for grep that handles long lines and -e... (cached) /bin/grep
 checking for cpp... /opt/rh/devtoolset-2/root/usr/bin/cpp
 checking if gcc supports -Wall... yes
 checking if gcc supports -Wmissing-prototypes... yes
 checking if gcc supports -ffloat-store... yes
 checking if gcc supports --exclude-libs... yes
 checking for flex... flex
 checking lex output file root... lex.yy
 checking lex library... none needed
 checking whether yytext is a pointer... no
 checking for bison... bison -y
 checking ieeefp.h usability... no
 checking ieeefp.h presence... no
 checking for ieeefp.h... no
 checking termios.h usability... yes
 checking termios.h presence... yes
 checking for termios.h... yes
 checking for vasprintf... yes
 checking for asprintf... yes
 checking for _LARGEFILE_SOURCE value needed for large files... no
 checking whether isfinite is declared... yes
 checking for perl... /usr/bin/perl
 checking for xsltproc... /usr/bin/xsltproc
 checking for convert... no
 configure: WARNING: ImageMagick does not seem to be installed.
 Documentation cannot be built
 checking for dblatex... no
 configure: WARNING: dblatex is not installed so PDF documentation cannot
 be built
 checking for xmllint... /usr/bin/xmllint
 checking CUnit/CUnit.h usability... no
 checking CUnit/CUnit.h presence... no
 checking for CUnit/CUnit.h... no
 configure: WARNING: could not locate CUnit required for unit tests
 checking iconv.h usability... yes
 checking iconv.h presence... yes
 checking for iconv.h... yes
 checking for libiconv_open in -liconv... no
 checking for iconv_open in -lc... yes
 checking for iconvctl... no
 checking for libiconvctl... no
 Using user-specified pg_config file: /usr/pgsql-9.6/bin/pg_config
 checking PostgreSQL version... PostgreSQL 9.6.11
 checking libpq-fe.h usability... yes
 checking libpq-fe.h presence... yes
 checking for libpq-fe.h... yes
 checking for PQserverVersion in -lpq... yes
 checking for xml2-config... /usr/bin/xml2-config
 checking libxml/tree.h usability... yes
 checking libxml/tree.h presence... yes
 checking for libxml/tree.h... yes
 checking libxml/parser.h usability... yes
 checking libxml/parser.h presence... yes
 checking for libxml/parser.h... yes
 checking libxml/xpath.h usability... yes
 checking libxml/xpath.h presence... yes
 checking for libxml/xpath.h... yes
 checking libxml/xpathInternals.h usability... yes
 checking libxml/xpathInternals.h presence... yes
 checking for libxml/xpathInternals.h... yes
 checking for xmlInitParser in -lxml2... yes
 checking for geos-config... /usr/bin/geos-config
 checking GEOS version... 3.5.0
 checking geos_c.h usability... yes
 checking geos_c.h presence... yes
 checking for geos_c.h... yes
 checking for initGEOS in -lgeos_c... yes
 checking for sfcgal-config... no
 checking whether make sets $(MAKE)... yes
 checking for a thread-safe mkdir -p... /bin/mkdir -p
 checking whether NLS is requested... yes
 checking for msgfmt... /usr/bin/msgfmt
 checking for gmsgfmt... /usr/bin/msgfmt
 checking for xgettext... /usr/bin/xgettext
 checking for msgmerge... /usr/bin/msgmerge
 checking for ld used by GCC...
 elf_x86_64
 -redhat-linux/4.8.2/ld -m elf_x86_64) is GNU ld... yes
 checking for shared library run path origin... /bin/sh: build-
 aux/config.rpath: No such file or directory
 done
 checking for CFPreferencesCopyAppValue... no
 checking for CFLocaleCopyCurrent... no
 checking for GNU gettext in libc... yes
 checking whether to use NLS... yes
 checking where the gettext function comes from... libc
 checking proj_api.h usability... yes
 checking proj_api.h presence... yes
 checking for proj_api.h... yes
 checking for pj_get_release in -lproj... yes
 checking json/json.h usability... yes
 checking json/json.h presence... yes
 checking for json/json.h... yes
 checking for json_object_get in -ljson-c... yes
 checking for pkg-config... /usr/bin/pkg-config
 checking pkg-config is at least version 0.9.0... yes
 checking for PROTOBUFC... no
 checking pcre.h usability... yes
 checking pcre.h presence... yes
 checking for pcre.h... yes
 TOPOLOGY: Topology support requested
 RASTER: Raster support requested
 checking for gdal-config... /usr/bin/gdal-config
 checking GDAL version... 2.3.2
 checking for OGR enabled... yes
 checking gdal.h usability... yes
 checking gdal.h presence... yes
 checking for gdal.h... yes
 checking ogr_api.h usability... yes
 checking ogr_api.h presence... yes
 checking for ogr_api.h... yes
 checking cpl_conv.h usability... yes
 checking cpl_conv.h presence... yes
 checking for cpl_conv.h... yes
 checking for library containing GDALAllRegister... no
 configure: error: could not find GDAL
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4259>
